#1 |
Only Happy When it Rains
Stripped Bolts
So I finally got a wrench that actually worked, and the only two bolts left to do are the ones I stripped yesterday. I'm going to give them one last try, but how do I get them out if they are completely stripped?
Oh, and another question, I can't seen to figure out how to get the top of the seatbelts out. I don't want to push too hard on the plastic, because I don't want to break it. Is there some trick I don't know, or is it simple pressure?
Colin Chapman disciple |
Get a wrench made by Snap On in the size that fits. They will work on the heads of nuts/bolts even if they are totally rounded off.
#3 |
![]() Drives: '08 liftback mt Join Date: Nov 2008
Use a dremel tool to turn the cap head into a slot head and use a big screwdriver.
#4 |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
cutoff-wheel, chisel, ez out? or, you can head to autozone and pick up a set of irwin extractors for about 20 bux. not bad seeing as how the snapon set which is made by the same company is almost 200.
#5 |
Chris
Drives: 2007 Yaris S Join Date: Dec 2009
I'm not sure what size. I just got done looking at it a few hours ago. I know there is a set you can get at sears or advance auto parts called bolt out. I'm going give it a try and let you know if it helps.
#6 |
Chris
I was wondering some cars had reverse thread. Do you know if that is the case?
#7 |
well, the easy thing would be vise grips for me depending on where they are and how big...anything up to about 15mm
or, drill and extract w ez-out, slot and use a freakin massive screwdriver...use a chisel and tap in reverse direction, like you're trying to back it out with the chisel... sometimes you can just hit it really hard in the center with a punch and it makes things easier to back them out. but like mentioned above, use a high quality 6-point wrench or socket made by snapon mac or matco. they have what's called flank-drive. it's set up to touch on the flats of the bolt, not the edges like cheapo wrenches and even craftsman. |
#8 |
Chris
Yes..I just use the bolt out and it works really well. I think the bolt however messed up the some of the threads though. I'm going to try a shorter bolt and see if it works, but new belt is on.
#9 |
reverse threads are usually only used on waterpumps. or fan clutches. i can't really think of any other application where one is used on a car.
| Tighten bolts to factory specs? | marlondog | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 10-19-2010 05:18 PM |
| Adjustable Camber Bolts | cali yaris | Micro Image | 30 | 12-11-2009 09:38 AM |
| Front Camber Bolts | lilredrocket | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-23-2009 11:57 AM |
| Are camber bolts needed after installing springs? | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-01-2009 12:19 AM |
| Trouble removing stock HU bolts | The Spectacle | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 10-28-2008 09:58 PM |
