Old 10-25-2006, 04:02 PM   #1
nsmitchell
nsmitchell's Avatar
Keyless Entry Chirp
Does anyone have a mod or know of a way to make a chirp signal when locking or unlocking the Yaris?
That was a nice feature on my Tacoma.
To lock my Yaris with no feedback, makes me look back and lock it.
Get YarAss in gear!
RIP - Casey Tatum
Old 10-25-2006, 06:46 PM   #2
paultyler_82
Does yours have the factory keyless entry, or aftermarket?
Old 10-25-2006, 08:12 PM   #3
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I have the factory set and I'd love a noisemaker too. Even a horn toot or something.
Old 10-25-2006, 11:18 PM   #4
Ayka
Drives: 07' Yaris HB | Blazin' Blue
The only "Signal" that the Factory can do is a Single Flash of the Hazard Lighting... as far as I could see over the Customization settings...
Ayka is offline   Reply With Quote
Old 10-26-2006, 04:39 AM   #5
paultyler_82
If you can find the signal wire from the alarm to the lighting, you can splice in a piezo buzzer or a relay to drive the horn.
Old 10-26-2006, 06:56 AM   #6
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
The first this I thought of... it looks like its time for someone to pull out the handy dany service manual...
will work for parts
Old 10-26-2006, 07:24 AM   #7
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Mine beeps becuz theres an alarm in it
2 beeps unlocked
1 beep locked
Old 10-26-2006, 08:00 AM   #8
i don't think the yaris has the RS3200 keyless entry system.
if it does.. well ... http://toyotasecurity.buypartsonline.biz/index.html
FIND THE MODULE now :)
Old 10-26-2006, 11:50 AM   #9
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
Send a message via MSN to Teruyume
Yaris does have a toyota security system offer to it. if u car equip with the system u will have the Beeping sound, if not only the flash.
06 Yaris RS 2Dr HB 5MT Orange
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Kumho Ecsta AST 195/50R15
Tanabe DF210
JDM LED Tail lights
Teruyume is offline   Reply With Quote
Old 10-26-2006, 12:16 PM   #10
Violin
Violin's Avatar
A little piezo beeper, a couple of wire leads with conectors and instructions could be a big hit on eBay Motors.
Old 10-26-2006, 03:07 PM   #11
Ayka
Where would you attach that though? Couldn't really attach it to the Hazard Lights, cause that would be as annoying as hell if you needed to use them, and I am not actually sure there is a physical wire travelling between that ECU that controls the door locks, and the Hazard lighting system, they may be the same ECU.
Old 10-26-2006, 06:35 PM   #12
Violin
Violin's Avatar
I was searching the manual today but didn't figure it out yet. I'm sure there is a way.
Old 10-26-2006, 08:21 PM   #13
paultyler_82
There should be a wire from the alarm/keyless module that hooks into the signal/hazard lighting system, THAT is the wire you want to tap, not the actual wiring for the lighting, you don't want the buzzer or horn to sound everytime you signal, only when the lights flash for lock/unlock. I30's and Maximas are the same way, with a visual signal only, and on that forum, someone merely located the keyless entry's light flash relay and hooked up a piezo buzzer to it, worked like a charm and had a nice high pitched beep like BMW's keyless entry system.
Old 10-26-2006, 10:41 PM   #14
as400g33k
as400g33k's Avatar
Drives: 05 YRS Silver Lining Metallic
hmm... I once drove a rental Camry (prev gen) that had an immobiliser/central locking but no alarm. And the horn beeps when you lock it and beeps twice when you unlock it.
as400g33k is offline   Reply With Quote
Old 10-27-2006, 12:30 AM   #15
Ayka
Even though I dont have a Wireless entry system, I've been pouring over the Wiring Diagrams for our cars looking for the Wire point that connects the EDLS (Electronic Door Lock System) to the Hazard lights.
and unfortunatly.. the connection is within the main ECU, there is no "wire" connection per-say that connects to the Hazard lights.
Pages 193-200 of the EWD.pdf in the Yaris Repair Manual.
Old 10-27-2006, 12:44 AM   #16
I have an aftermarket (but toyota-branded, dealer-installed) remote door lock on mine, and it does beep when locking/unlocking. Strangely enough, I'd prefer to disable the beep, it kinda annoys me each time, I prefer just the stealthy blinking of the signal lights. But that's just me
Old 10-27-2006, 01:12 AM   #17
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
I'm with you
I don't usually arm my alarm at home because I hate the chirps every single time i walk away or up to my car.
My sister inlaws cobalt honks the horn everytime the car is locked and unlocked and it's very annoying to them and her neighbours.
Old 10-27-2006, 11:03 AM   #18
barryware
I added a keyless entry to mine. The hardware also came with a remote start. If you have an aftermarket setup, you can change the programming and make it beep or not.
I had mine installed and it took a fight with the installer to have them give up the installation manual. They typically give you the owners manual but it is the installation manual that you need to make programming changes.
They said: "We don't give the installation manual to the customer"
I asked: "Did in come in the box"?
They said: "Yes"
I asked: "Did I pay for the box"?
They said: "Yes"
I said: "Then I paid for it and I want it"!
They said: "Ok but if you screw up the programming, we will not warranty it"
I said: "what ever".
The system I got was a Python something or other. I am a do it your self'er but the manufacturer does not give any end user support so I thought it best to have it installed. Actually, the price included installation and was not available without installation.
My point is.... Most if not all remote / alarm systems allow you to change they way it works but you must have the documentation. Without it, you are pretty much up the creek.
My Ranger had a factory keyless entry and alarm. You could change the beeps and flashes by a series of key presses on the remote and turning the ignition on and off a bunch of times. The end user could if they knew how but it is not documented. The dealer can change the programming but they will charge you for it.
Documentation is mans' best friend!
barryware is offline   Reply With Quote
Add remote to factory keyless. imknotright DIY / Maintenance / Service 50 03-24-2018 12:10 PM
Keyless Entry BLKYRSSDN In Car Entertainment + Electronics (audio / video / alarm) 44 09-16-2007 10:27 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
keyless entry question? punch General Yaris / Vitz Discussion 4 05-26-2006 12:46 PM
FS Various OEM keyless Remote riceboy Items for Sale by private party 0 04-14-2006 02:42 PM
