Old 10-29-2009, 01:58 AM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Replacement wiper blades
So we had our first good rain for this season a couple of weeks ago and I noticed that my wipers weren't doing a good job. After spending about 30 minutes in a local auto parts store I decided to try out the Bosch ICON, since I like the wind spoiler feature. I only got the one for the driver's side, thinking that if I don't like it, I'll return it right away.
After installing it, I was so impressed that I went back inside to get the passenger's side. The problem is, the smallest they have is 16" and I need 13". Any ideas where I can find a blade with this design (the wind spoiler) in 13"? I looked on Amazon, other online stores, couldn't find a 13" blade with a wind spoiler on it.
A couple of days later I checked the blades on my wife's car (2008 Scion xD) and her stock blades have the spoilers. Dang! And I haven't measured it, but it looks like the passenger blade is the same size as the one on the Yaris. So is my only chance to get one at the dealership? I don't want to pay the delership premium fomr something that should be $20.
Old 10-29-2009, 02:51 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Price it and find out. I don't think they would price themselves out of the market.
Old 10-29-2009, 07:12 AM   #3
Dealership replacement inserts FTW!!
Old 10-29-2009, 02:54 PM   #4
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
+1
aca72 is offline   Reply With Quote
Old 10-29-2009, 04:31 PM   #5
gswell
Drives: yaris 07
can you elaborate?
gswell is offline   Reply With Quote
Old 10-29-2009, 04:35 PM   #6
bladesmith6
Drives: 2007 yaris HB
Just so everyone is aware you can take apart a the Rain-X Latitude cut them down and re-assemble for the passenger side if you are careful. I got tired of trying to find a uniform pressure blade in the small size "13-14" so I bought a 16" and cut it down, works great.
bladesmith6 is offline   Reply With Quote
Old 10-29-2009, 04:45 PM   #7
Originally Posted by gswell View Post
can you elaborate?
Rather than buying a whole new wiper, you can get and replace just the rubber blade from the dealership. I discovered this after I bought a whole new wiper from them once. I don't know about U.S. pricing, but an insert should be about 1/3 (or less) the cost of any whole blade replacement option.
Old 10-29-2009, 05:48 PM   #8
fmicle
fmicle's Avatar
But I need the wind spoiler wiper first and then I can replace the blades only. My problem is that I can't find a 13" wind spoiler wiper. I thought about getting the smallest available (16") and cutting it, as suggested above, but I was concerned whether I could to a clean cut
Old 11-02-2009, 09:40 PM   #9
captainm27
Drives: 2008 Sedan A/T Silver
I know the pain of trying to find the small wiper. My Sedan uses a 14" wiper, and the only brand I can find that makes it so small is one called (ironically enough) Exact Fit at my local Advance Auto Parts.
captainm27 is offline   Reply With Quote
Old 11-03-2009, 08:05 PM   #10
aca72
aca72's Avatar
You mean the fancy "aerodynamic" wiper blades?
Trico NeoForm "aerodynamic" beam blades has our size (26/14).
Rockauto.com sells them. To get a discount, Google "rockauto discount code".
There is also a manufacturer rebate @ TricoRebates.com.
Happy hunting!
Old 11-03-2009, 09:13 PM   #11
Lafiro
Drives: 06 Yaris Sedan
I want to see pictures, of both sides, and from the center view so I see how it looks.
I will probably do the same now that you have good luck with it.
Also, what size wipers does the sedan need? I got the 07. I don't know the exact sizes. I want to know so I can buy the fancy wipers that all nice cars/new cars are coming out with.
THey are aerodynamic, and have better cleaning of the windshield.
Old 11-03-2009, 09:44 PM   #12
bladesmith6
i'll see if I can get a few pics tomorrow.
Old 11-04-2009, 10:52 AM   #13
are you sure? because the sedan is tight fit for a 13", you cannot over size to 14...
the LB does take 14 though.
Old 11-04-2009, 06:30 PM   #14
bladesmith6
Here are some pics of the one I cut down:
Old 11-04-2009, 07:20 PM   #15
MadMax
MadMax's Avatar
You are a friggin' genius!
Do you know if this mod can be done on other manufacturers blades?
Old 11-04-2009, 07:45 PM   #16
Lafiro
Thank you!
How do the rain-x wipers work? Im using a regular one right now for the passenger, and it SUCKS!
Old 11-04-2009, 08:41 PM   #17
fmicle
fmicle's Avatar
Looks perfect to me. What did you use for cutting? I have a bolt cutter somewhere at home, do you think that would work? There is a metal strip inside the blade somewhere, isn't there?
Old 11-04-2009, 08:57 PM   #18
bladesmith6
Thanks guys, you will need a small flatblade screwdriver, wiss snips and a razor knife. You use the screwdriver to pop the end caps off and thats the hard part because you have to twist pretty hard but they will come off. Then take inner pcs apart(metal backer, plastic body and the rubber wiper) cut the metal pc with the snips, the plastic you can use the razor or a hacksaw blade, and rubber wiper with the razor, reassemble put a dab of adhesive inside each end cap and your good to go. You have to use a wiper with removable end pcs or I don't think this will work.
Wiper blades .... Lafiro General Yaris / Vitz Discussion 81 02-02-2012 06:54 PM
Wiper Blades futdechenes General Yaris / Vitz Discussion 44 06-27-2010 11:08 AM
new pics thebarber Photo-Video-Media Gallery 19 08-27-2009 09:01 PM
What kind of wiper blades? buyah123 DIY / Maintenance / Service 9 11-25-2008 05:25 PM
