Old 10-29-2009, 01:07 PM   #1
RickLew
Drives: 2007 Toyota Yaris
Battery light stays on
I have a 2007 Yaris with 88,000 miles. For the past two months my battery light in dash stays on if I let the car sit for a day or two. After driving it for 2 or 3 days, the light goes out again and stays out unless I let it sit again for a day or two. Anyone else dealing with this? Possible causes?
Thanks
RickLew is offline   Reply With Quote
Old 10-29-2009, 01:12 PM   #2
There is a TSB that could be relevant to what you are experiencing.
I have same sort of issue periodically. Usually happens to me when there is an extreme amount of moisture in the air. Goes away after the atmosphere has dried out.
http://www.etimago.com/yaris/TSB/T-E...t%20ON%20).pdf
Old 10-29-2009, 01:30 PM   #3
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
for some reason his link is blocked at work
is this with the check engine light that comes on? Mine comes on right before it rains or gets a lot of moisture in the air, then goes away a little bit later.
I didnt know there was at TSB for it
http://www.4055design.com
Old 10-29-2009, 01:51 PM   #4
supmet
Drives: 2007 4 Door Yaris
88,000 miles + letting your car sit a lot for days at a time = time for new battery
Old 10-29-2009, 01:58 PM   #5
Not the check engine light. He would be referring to the red battery symbol. The TSB deals with an issue of corrosion in the voltage regulator on the alternator.
Old 10-29-2009, 02:18 PM   #6
kustom play
Drives: 07 liftback
ohh ok
i cant see the link at work
i have the issue with the check engine light coming on then going off when its humid
im going to wait and get the code next time with my scan guage
Old 10-29-2009, 03:07 PM   #7
RickLew
Thanks WeeYari, I printed the TSB and will try.
Light weight race battery. buddyjim Performance Modifications 24 01-27-2009 08:33 PM
6lb 6oz ultra light weight battery heavystarch Performance Modifications 28 11-19-2008 06:02 PM
