Old 11-01-2009, 03:33 AM   #1
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
Fake alarm light
yeah so i dont have the $$$ to spend on an alarm. BUT i have all these components to build this ->http://www.discovercircuits.com/DJ-C...kecaralarm.htm can i apply this to the yaris (2009)? i am fairly competent with a soldering iron and know my way around wires and such. the only hard part would be locating the wires. but i need to know if this circuit wont freak out the yaris in ANY way at all.
thanks for your input.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 11-01-2009, 06:34 AM   #2
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Looks like that drawing is using a simple JFET or transistor to switch power to a flashing LED. Only problem is I've never come across a "flashing LED" as in a self-contained unit. Regular LED's are fairly common, so if I were to build this circuit I would use a regular LED driven by a 555 IC timer in astable mode to get the flash effect. Fairly easy circuit to build and the parts are certainly very common. Something like this:
http://wild-bohemian.com/electronics/flasher.html
We have our students build these circuits all the time and they last forever.
Note: Obviously it would not be a good idea to connect this circuit to your ignition wiring directly but to something that is powered via the ignition switch signal... like your radio.
RUFFSTUFF is offline   Reply With Quote
Old 11-01-2009, 12:39 PM   #3
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Here is one that is plug and play http://appsdiscounts.com/Site/Home-1.html $7.00 shipped
POORSHA is offline   Reply With Quote
Old 11-01-2009, 12:57 PM   #4
127.0.0.1
radio shack sells 12v blinking leds for 2 bucks
Old 11-01-2009, 01:37 PM   #5
supmet
Drives: 2007 4 Door Yaris
why? Is someone really gonna try to break into your car and be scared away by a blinking light? They don't get scared away half the time when real alarm start going off. I would think a viper license plate frame or sticker would be more effective.
If you're good with soldering/electrical, why don't you try to find a cheap used alarm somewhere and make it work?
Old 11-01-2009, 02:35 PM   #6
RUFFSTUFF
Nice find!
kewl.
Old 11-01-2009, 08:44 PM   #7
sıɹɐʎ
Economist
sıɹɐʎ's Avatar
Drives: 2007 Yaris Lifback
I have a fake alarm light. I went through quite a few different LEDs, because most of the flashing LEDs you can find online or at the shop (or at least Radioshack) flash at far too quick a rate to be the slightest bit convincing. (And, of course, half the time the flash rate isn't advertised.) I recommend the Varad LL-RE; it has an adjustable flash rate, draws under 20 mA, and is much, much, much less frustrating than getting one that flashes 100 times a minute.
sıɹɐʎ is offline   Reply With Quote
Old 11-06-2009, 04:35 AM   #8
Cosmonaut
The Last Baron
Cosmonaut's Avatar
thanks for the input guys.
ruffstuff :i was previously looking at a timer circuit so ill keep that in mind.
supmet: the point of this was that i have all the parts laying around in a box and to keep cost to an EXTREME minimum. i know the people who really REALLY want to get in will do so but what i dont want are the little assholes(we have mostly kids in the neighborhood that will not contribute positively to society) who walk around messing with shit trying to get in my car, so yes i do hope that a small blinking light will scare them however unrealistic that may seem. thanks for the suggestion about the viper sticker i should find a couple of those.
| UR 19mm sway |
Old 11-06-2009, 12:46 PM   #9
Got Mine
Drives: 2009 5dr
This is too weird....
I have a 2009 LB ( not sport) and I have a blinking dummy alarm LED by the outside edge of the driver's side defrost duct...
Am I special or is mine really a self destruct indicator..?
Got Mine is offline   Reply With Quote
Old 11-06-2009, 01:04 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
why not go ahead and build an alarm while you're at it?
Old 11-06-2009, 03:43 PM   #11
sex
sex's Avatar
Drives: 09 5DR
cosmo >> is this cheap enough? http://cgi.ebay.com/ebaymotors/ws/eB...m=380169604483
got mine >> that's the immobilizer led
Old 11-07-2009, 12:18 AM   #12
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Tamago i think i will build an alarm and wire it to a "backseat monkey" that throws stuff at anyone who tries to enter.
seriously though the initial idea was that i literally had these resistors and transistors so my cost would be $ZERO.
but that link sex posted looks very interesting. thanks sex i need to look into that one.
| UR 19mm sway |
Old 11-07-2009, 01:57 AM   #13
YarisSedan
Drives: 08 Yaris Sedan
This is what you need!!!!!!!!!!!!
http://www.youtube.com/watch?v=zdPdbHxFgrQ
Old 11-07-2009, 05:25 AM   #14
fujiwaru
fujiwaru's Avatar
Drives: 08 Toyota Yaris Sedan
haha i think thats what everyone needs!! funny vid!
- Arvin
fujiwaru is offline   Reply With Quote
Old 11-07-2009, 11:48 AM   #15
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You have an immobilizer. The engine can't start without your key.
Old 11-09-2009, 07:10 AM   #16
Got Mine
Drives: 2009 5dr
TY
Forgot about the $200 immobilizer key...
Old 11-09-2009, 08:38 AM   #17
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
I've never seen anyone pay any attention to a car alarm, other than to express annoyance if it keeps on going and going...
They're useless.
Old 11-11-2009, 11:22 AM   #18
RUFFSTUFF
They're useless.
Hardly. When insurance companies stop giving discounts for car alarms, then they could be considered useless. They don't cut into their profit margin for no reason. Alarms are supposed to be annoying, that's why they are called "alarms" and not "excuseme's"...
Scorched Earth!
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
VIP Alarm V3 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 6 08-04-2009 01:43 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
