Old 11-02-2009, 08:40 AM   #1
SoundWave
Drives: 2008 toyota yaris
Send a message via Yahoo to SoundWave
interior/exterior lights
hello everyone, i own a '08 yaris sedan and I have encountered a problem last night. i was on my way home and my lights inside the car and my headlights were blinking at the same time,could it be the battery or a blown fuse? and everytime i turn my steering wheel, all the lights starts to dim a little bit,please let me knnow thanx guys!
SoundWave
SoundWave is offline   Reply With Quote
Old 11-02-2009, 10:33 AM   #2
Check the headlight switch connector. When I was doing some wiring on the column I noticed that wiggling the connector would make the headlights flicker. It turned out that the ground pin on the connector was a bit sloppy, so I popped the pin and bent it a bit to make it tight.
Old 11-02-2009, 03:05 PM   #3
SoundWave
Where would the headlight switch connector be?
Old 11-02-2009, 03:11 PM   #4
At the base of the headlight stalk. You have to remove the lower steering column cover to get at it.
Old 11-02-2009, 03:21 PM   #5
SoundWave
Thanx ctscott
