Old 11-08-2009, 04:13 PM   #1
chart45
Drives: paseo 4age 20v blacktop
4age bt turbo
ok i new here. i found this site by googoling blacktop turbo and finding the turboecho2005 echo project. now i want to know witch fuel management this guy was using to run his blacktop to 8.5 psi on stock internal, cause now my paseo need more power and i'm new in the toyota world i was from the obscure side of the force with a lot of honda swap and turbo project but now with my paseo 4age bt swap project i need advice to go fast in that turbo project.
i'm sorry for my bad english
there is my paseo bt 20v
and now my first toyota swap sorry for the purist
http://www.youtube.com/watch?v=xhyT4gRz5Hg
chart45 is offline   Reply With Quote
Old 11-08-2009, 09:18 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
did you try to PM him?
Old 11-08-2009, 11:33 PM   #3
he was using MegaSquirt fuel management.
Old 11-09-2009, 11:31 AM   #4
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
For a low boost application an economical option would be an AEM FIC.
Then again... the BT is not the best suited engine for force induction. 11:1 CR and skiny con rods. I would not suggest pushing more than 8 psi and that is with a very good tune.
Old 11-09-2009, 04:28 PM   #5
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
That's me. 8.5 - 10psi won't be a problem. 11-14psi can be done with water injection which I plan on doing soon. Remember psi doesn't mean anything until you specify what turbo you are using. I am using a gt28 with a 60 a/r. Most importantly you need to have a rock solid tune. My car was tuned for almost 4 weeks to make sure everything was perfect.
Obviously you cant run 8.5 psi with stock internals and a gt30 turbo.
And I was using megasquirt.
248hp to the front motor
255hp to the rear motor
if you need any parts let me know. I work for turbinetech ;)
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 11-09-2009, 10:00 PM   #6
chart45
if i'm using megasquirt do they sell ecu patch harness or i will have to rewire everything cause i just finish to rewire the complet paseo and wich injector do you use??? the last turbo setup i did i was using a smt6 with 2 fuel rail the fisrt rail was the stock h22 345cc injector and the second one was the dsm 450cc injector so in full boost its about 795cc
thanks for help
Old 11-10-2009, 04:34 PM   #7
turboecho2005
I sent you a PM
Old 11-11-2009, 03:51 PM   #8
I think the smaller choice a/r is .64 on the Garrett at least, the large one is .83 or something like that? I used the smaller one too.
Old 11-11-2009, 04:36 PM   #9
chart45
where did you get your intake plenum to suit your turbo setup on the 4 itb
Old 11-11-2009, 04:56 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
i think some of us should read this...
http://www.toysport.com/technical%20...tech_notes.htm
Old 11-12-2009, 12:40 PM   #11
turboecho2005
Garm you're right it's a 64 a/r.
We put a turbo setup on my buddys Sentra spec v. Stock engine running 14psi on a t3/4 turbo. Just throw in a wide band and crank the boost. As long as you don't lean out you keep upping the boost.
The intake plenum was made by turbine tech.
Old 11-12-2009, 07:36 PM   #12
chart45
ok for the plenum i take a look to turbinetech and they got a lot of stock for suzuki but did not find any toy plenum do you have to make a special order??? now witch injector did you use i find out that i can use any toyota side feed injector.. i don't want to go more than 8psi so should i use the 3sgte 340cc supra 440cc or supra 550cc injector???
Old 11-13-2009, 09:16 PM   #13
chart45
ok yesterday i leave a email to the turbinetech guy and they reply me with this
this is what you have ???
i was thinking about something like that
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
