Old 11-22-2009, 04:37 PM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
I'm stuck - front springs and shocks
I can't loosen the f*cking bolt at the top of the shock.
This is what happened to my allen key
And this is how the bolt is looking like right now:
Any ideas?
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 11-22-2009, 04:50 PM   #2
1NZYaris1
1NZYaris1's Avatar
Hire a impact gun , worked for me .
Old 11-22-2009, 05:23 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Did you try using a breaker bar on your wrench? Looks like you need lots more leverage.
Old 11-22-2009, 05:52 PM   #4
fmicle
fmicle's Avatar
...or just get the right damn tools... Went to Autozone and picked up a set of box wrenches with a deeper offset. Worked like a charm on the 2nd try... Now I feel like an idiot
Old 11-22-2009, 06:15 PM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Good thing you got the right tools. Luckily that nut still had meat to grab on
or you would've been in an even bigger mess. Good job! You're installing drop springs I assume?
Old 11-22-2009, 06:36 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Thats what happens when you use cheap tools. Get a good allen wrench key and use a pipe on the end. Thats what i did and had no problems.
Old 11-22-2009, 06:38 PM   #7
1NZYaris1
1NZYaris1's Avatar
Ahhhh at least you got the balls to admit it lol,
keep it up your almost done
Old 11-23-2009, 01:22 AM   #8
fmicle
fmicle's Avatar
Well, I didn't want to be an ARROGANT idiot
Old 11-23-2009, 02:04 AM   #9
advocate
Drives: car
Glad things are going well fmicle. Remember I want to see those wheels...
Old 11-23-2009, 02:37 AM   #10
fmicle
fmicle's Avatar
In pictures or in person? Either way is fine with my by the way
Old 11-23-2009, 12:25 PM   #11
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
coca cola
yaris 2sz is offline   Reply With Quote
Old 11-23-2009, 01:12 PM   #12
had a similar thing happen w/ mine
had to use an air impact wrench and a half can of liquid wrench to get the top apart
other option: compress the spring to relieve the pressure on the plate, then hold the plate and use an impact wrench.....had to do something similar to that too....
edit: but now i see you got it apart...
New OEM KYB '07 Liftback Springs & Shocks (Struts) GuySmily Items for Sale by private party 7 07-25-2010 05:02 PM
Tanabe NF210 + Tokico vs. TRD springs and shocks fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-19-2009 03:42 PM
What Shocks for Eibach springs? ibizagti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 03-26-2009 05:38 PM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 09:54 AM
Newbie needs help with springs and shocks xray scatter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-21-2008 12:39 PM
