Old 11-25-2009, 02:08 PM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Toyota about to recall 4 million vehicles in US
http://news.yahoo.com/s/ap/20091125/...ota_floor_mats
don't know if the newer model Yaris is affected. But i did read an article, where a California HP officer, off duty, was killed while driving a Lexus.
Yawesh is offline   Reply With Quote
Old 11-25-2009, 02:24 PM   #2
127.0.0.1
although the problem is: the driver not knowing how to shift
to neutral, and therefore getting out of control.....
toyota is admitting they built the accel pedal lip too close to the floor,
which does allow a mat to stick it to the floor
then
others have reported the problem occurs with NO floor mat. but NHTSA
has examined toyota drive-by-wire modules and they can find no electronic
pr programming faults
take everything with a grain of salt
toyota will re-engineer the accel pedal to have enough clearance at the bottom lip
to never get stuck on any floormat
plus put in an idiot box in new models to cut gas when the brake and accel is pressed at the same time
Old 11-25-2009, 02:26 PM   #3
YAR1S
YAR1S's Avatar
Why can people figure out that shifting it into neutral will get you out of this problem in some cars!! I know others you have to engage the brake but with our cars, you simply have to shift it out of D and into N.....
what a shame....
I think our accelerator is too close to the right middle column..... always feels like I dont have enough control of it with the limited contact.
-Jen <3
Old 11-25-2009, 02:59 PM   #4
127.0.0.1
what a shame....
all cars can be shifted into N from any drive position
if this fails
all cars can be shut off
if this fails
all cars have brakes that can overcome the engine
the failure is, in a panic mode, people still don't want to risk damage to
the car from over-revs, or burning out the brakes...or they just lock-up
the thought processes in a sheer panic and can't think.
automakers need to engineer 'around' human habits
Old 11-25-2009, 03:05 PM   #5
tomato
tomato's Avatar
Same thread in the off-topic section already:
http://www.yarisworld.com/forums/showthread.php?t=24221
Old 11-25-2009, 03:25 PM   #6
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
One of the features that I absolutely love about my Yaris is that the driver's carpet is held in place with 2 plastic hooks, so it can't move forward. I'm having a hard time removing it when I want to clean it actually
Besides, I have a manual transmission, so a jammed gas pedal doesn't scare me at all...
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 11-25-2009, 03:40 PM   #7
tomato
tomato's Avatar
Manual transmission FTW !!
Old 11-25-2009, 03:48 PM   #8
eht13
Drives: .
No Yarii are affected.
"The models involved are: 2007 to 2010 MY (model year) Camry, 2005 to 2010 MY Avalon, 2004 to 2009 MY Prius, 2005 to 2010 MY Tacoma, 2007 to 2010 MY Tundra, 2007 to 2010 MY ES350, 2006 to 2010 MY IS250, and 2006 to 2010 MY IS 350."
http://abcnews.go.com/images/Blotter...aStatement.pdf
eht13 is offline   Reply With Quote
Old 11-25-2009, 03:56 PM   #9
nemelek
DWEED
nemelek's Avatar
I had an 04 Dodge Ram that had an out of park alarm recall. It was a simple 10 minute reflash proceedure. I always thought that it was a good was for Dodge to get people into their shop and hit them up for more service work. If 1/2 of the people have other service work preformed, the dealer will make money.
Old 11-25-2009, 04:04 PM   #10
EleKid
Eugenie たでし
EleKid's Avatar
Drives: '09 Blazing Blue Liftback
I think Yarii aren't getting recalled because we don't use a sensor for our pedals right?
EleKid is offline   Reply With Quote
Old 11-25-2009, 06:37 PM   #11
I drove a lexus, similar to the one involved in the accident.
The start button SHOULD stop the engine even in motion.
Park, neutral and reverse can be shifted into from D (drive) even in motion, and that, without having the step on the brakes. this is not new, it's been like this since forever.
Besides, the brakes always work, at no matter what speed you are going at. It's not like the brakes stops working in this kind of situations (often seen in movies, where there's always a bottle of water getting stuck behind the brake pedal!!! lmao)
Last... I seriously believe this is a really stupid prank someone tried to make up and ended up killing themselves.
The only possible cause for this i think is a failure of the throttle position sensor.
Oh.. i almost forgot. ALL toyota vehicles have their floor mats clipped, at least, on the driver's side, so they cannot move forward to get stuck behind the pedals since at least the 2000's.
Old 11-25-2009, 06:38 PM   #12
the yaris is drive by wire... I can't wait to see if the throttle sensor will eventually fail and hit some WOT without the interaction of the driver.
Old 11-25-2009, 07:43 PM   #13
supmet
Drives: 2007 4 Door Yaris
I agree its being blown out of proportion, but:
1)I believe the mats in question are plastic winter mats that don't clip in
2)The mats got stuck under the brake, on top of the gas, making braking hard, but as you said, not impossible.
My guess is all accidents were really caused by greasy fast food wrappers in between mats which lowered the friction, allowing them to slide around.
Oh and ya, shifting in to neutral will keep you from getting to 120, last time I checked.
My brothers old 93 camry had the cruise control fail and stick the throttle open.. it happens, and isn't the end of the world.
Old 11-26-2009, 11:06 AM   #14
markitect
Or the person is stepping on the gas instead of the brake.
markitect is offline   Reply With Quote
Old 11-26-2009, 11:54 AM   #15
MUSKOKA800
MUSKOKA800's Avatar
My OEM (Toyota Canada) winter mats do use the same plastic hooks to secure them in place. Of course, the summer mats must be unhooked and removed first.
Old 11-26-2009, 12:51 PM   #16
texkid
The one with cheese on it
Drives: '10 Corolla S
Being that I now own a 2010 Corolla, I do feel that I had to mention that I was not able to order all-weather floor mats due to this recall even though that the Corolla vehicle was not on the recall list.
After contacting corporate, I learned that they are suspecting all the "winter" rubber floor mats regardless of model or method of installation.
Now, I am not sure if US Corolla's have the option of push-button features, but in my Corolla manual (if people just took 15 minutes to READ) it does state that if you need to make an emergency shut-off that you push-and-hold the button for 3 seconds. So....people cannot say that Toyota did not provide some sort of safety measure. And yes, ALL vehicles (regardless of make, model, or AT vs MT) have the ability to shift into neutral.
The other side of the coin is that some people just plainly freeze in emergent situation. Not everyone have the "nerves of steel" or are prepared for a runaway car.
AND.....one more thing I did notice. My carpet floor mats seem "shorter" than compare to other floor mats (i.e. the Yaris). They stop right before the pedals. Take into consideration that my car hit the lot in mid-October, I guess Toyota has been making corrections for quite some time.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 11-26-2009, 02:03 PM   #17
fmicle
fmicle's Avatar
Yep, this actually happens more often than you would think.
Old 11-26-2009, 02:53 PM   #18
It was on the newspapers today...
They say Toyota is going to put a feature for all 2010 models, so that if you step on the gas ans the brakes at the same time, it will shut off the engine.
Now, can you believe you won't be able to heel/toe anymore? I wonder if it applies to MT.
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Ford to Recall 3.6 Million Vehicles Due to Fire Risk death is my gift Off-topic / Other Cars / Everything else Discussions 13 08-08-2007 07:14 AM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
