Old 11-26-2009, 11:53 PM   #1
detroiter
detroiter's Avatar
How much carbon residue on muffler is acceptable?
Just a curious question that popped into my head earlier and though I'd ask. I know some cars (new ones), you couuld clean the exhaust tip clean and by the end of the days worth of driving, it's coated in carbon. Then other cars it seems, you could drive them hard and for a long period of time and they won't seem to have any sort of residue on their mufflers.
Old 11-27-2009, 12:12 AM   #2
ddongbap
W/e the amount is that lets you pass smog.
Old 11-27-2009, 12:19 AM   #3
detroiter
detroiter's Avatar
The beautiful thing is Michigan doesn't have emissions testing :D
I guess what I'm getting at is what is an acceptable amount of black carbon being left behind before you should be concerned something is wrong?
It's interesting to me that some cars you drive normal or romp sometimes, they have a ton of carbon residue yet other cars driven likewise are spotless. What is it that dictates it being like that?
Old 11-27-2009, 12:44 AM   #4
YAR1S
YAR1S's Avatar
i get quite a bit of carbon on my muffler tip....kinda lame.... but oh well.
-Jen <3
Old 11-27-2009, 03:08 AM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Carbon build up doesn't mean something is wrong. In newer cars at start up the engine will run rich and the cat is not warmed, so you will tend to have unburned fuel out of the exhaust, carbon. After the engine is warmed and the cat is heated, the exhaust will have completely burned fuel. This will burn off some carbon build up because of the high heat produced by the cat. What will cause carbon build up is a lot of cold starts and short trips.
Old 11-27-2009, 08:48 AM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
When you stomp on the gas pedal and exceed around 70-80% of maximum engine load, the ECU goes into open loop mode and enriches the mixture, commonly enough to soot up the pipe. My Yaris never blackens the chrome tip during cold engine warmup, but does if I go to wide open throttle.
Old 11-27-2009, 01:45 PM   #7
Vang
Drives: 2008 Yaris Sedan
i drive like a granny and my exhaust tip still looks new
Vang is offline   Reply With Quote
Old 11-28-2009, 11:04 AM   #8
127.0.0.1
the exhaust tip should be clean. constant soot indicates a problem.
my 12 year old 4runner only got soot once in a 2 month period when the a/f sensor went kaput. changed it and the tip went back to clean.
Old 11-28-2009, 01:10 PM   #9
RedRide
RedRide's Avatar
Yes, a little soot on the inside it the tail pipe is completerly normal if you don't drive like a '99 year old granny.
Personally, I always drive a bit agressively, frequently access WOT, and have always had some soot in the tail pipes on all my cars.
Old 11-28-2009, 01:15 PM   #10
RedRide
RedRide's Avatar
Personally, I always drive a bit agressively and have always had some soot in the tail pipes on all my cars.
Also, if you live is a colder area (or where there are cold winters) the engine runs richer for a short while when first started in cold weather.
Rusty Muffler dadi_oh Cosmetic Modifications (Exterior/Interior) 7 07-03-2009 08:45 PM
new axle back exhaust. carbon fiber Hindle. andruboz Performance Modifications 20 05-22-2009 11:22 AM
Rusty Muffler Hangers YAR1S General Yaris / Vitz Discussion 14 10-24-2008 07:22 PM
Carbon offsetting with TerraPass BailOut General Yaris / Vitz Discussion 14 05-28-2007 12:29 AM
Muffler Tip ~ Good Idea? jaspie Cosmetic Modifications (Exterior/Interior) 14 01-17-2007 07:34 PM
