Old 11-28-2009, 12:57 AM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Big boo-boo happened today...
So, eventually it was meant to happen... after all the mods so far went more or less smooth and without problems, I finally screwed up
I took the alternator out and, stupid me, didn't bother to disconnect the battery. Moronic, I know, it won't happen again. When I was putting it back, something happened, some wires touched each other somehow and I had a big spark. Nothing else, no white smoke, no funny smell, I disconnected the battery and finished reinstalling the alternator.
After some troubleshooting and research, I believe I blew one the main fuses that sits on the positive terminal of the battery, #52 in my manual, called ALT 120 A and it's responsible for half the car's electronics...
Those 2 fuses are funny looking and I was wondering where can I find replacements? Pepboys, Autozone or does only Toyota have those?
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 11-28-2009, 12:59 AM   #2
YAR1S
YAR1S's Avatar
yikes..... I say go to toyota but they'll charge you two arms and two legs.....
-Jen <3
Old 11-28-2009, 01:09 AM   #3
YarisSedan
Drives: 08 Yaris Sedan
You might get lucky at a local parts house. Otherwise its to the dealer. Sometimes those main fuses can be costly like 40-75 bucks. You could temporarily and i mean only temporary pop the plastic cover off and solder the fuse back together.
Old 11-28-2009, 01:11 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Those places you mentioned should have it. Bring your blown one for them to see.
It might cost a little more than a "normal" fuse but still way cheaper than Toyota.
I replaced some main fuses from my other Toyota at a local parts store.
Old 11-28-2009, 01:43 AM   #5
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Is the main fuse the same as the old buss fusible link? I can't tell by the size of it in the pic. If it is a buss, then any auto parts store should have it. I've blown one on my first car after it touched metal (it was a salvage and the body repair shop didn't install a new mounting bracket). It only cost me about $5 at AutoZone at the time.
Edit: this might help: http://www.autozone.com/autozone/cat...&parentId=57-0. My money's on the 4th one
Old 03-21-2013, 04:44 PM   #6
frankieschl
Drives: 2007 toyota yaris
I just did the say thing. Where did you finally get the part from???
frankieschl is offline   Reply With Quote
Old 03-21-2013, 05:52 PM   #7
hw6515
Drives: 08 Yaris AT, 350Z GT MT
Look in this thread. Has a pic and the part number. You can fix that one in the mean time, let me know if you need some help on how to.
http://www.yarisworld.com/forums/showthread.php?t=43996
hw6515 is offline   Reply With Quote
Old 09-09-2015, 11:33 AM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Thread necro!
I blew my ALT fuse this morning. The plastic cover to the alternator is no longer present (broke off when installing the supercharger), and I contacted it when trying to tighten the alternator bolt. It's a Toyota-only part, not stocked at my dealership. Good news is it's only $18, bad news is it won't be here until tomorrow. I ordered 2 so that I don't leave myself stranded like this again.
Old 09-18-2015, 08:14 PM   #9
xdarkxfirex
Drives: 2015 yaris le
Been there done that. I thought it could've been that, and I have a tow service, towed to the dealer on a Saturday, they didnt get the part till Tuesday and charged two hours labor. Part is less than $20 at the dealer, dont think they make an aftermarket.
xdarkxfirex is offline   Reply With Quote
Something strange happened today Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 05-08-2009 11:40 AM
