Old 12-05-2009, 04:21 AM   #1
ztlonewolf
ztlonewolf's Avatar
Drives: 2008 red 3 dr S coupe
should i get alternater/battery checked?
ok,i drive a 08 3dr,it has 34,000 miles on it,lately i have been noticing at night that when i apply the brakes,all the lights go dim and then brighten back up,is this a problem i should have checked, or am i just being a worry wart seeing how the warranty is almost done,there are no warning lights whatsoever and i have no problems starting the car,any ideas?
ztlonewolf is offline   Reply With Quote
Old 12-05-2009, 05:02 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Something sounds like its not working right,could be defective alternator or battery,i'd definitely bring it to the dealers attention..
Old 12-05-2009, 02:44 PM   #3
supmet
Drives: 2007 4 Door Yaris
sounds like the alternator... and yes you should have it checked
Old 12-05-2009, 07:14 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
sounds normal to me... unless the dimming is HUGE or you notice your engine start to hiccup/drop rpm's at the same time.
go ahead and have your bat and alt checked cause its winter.... but really... lights dim... its what they do... a .5 volt dip can cause noticeable light dimming.
Upgrade the alt to chassis ground, and battery chassis ground cables to 4awg or 1/0awg to help improve your electrical system's efficiency. Shouldn't cost you more than $20... buy your cable at a welding supply store, its much cheaper and just as good, if not better than the wire you'll buy anywhere else.
Old 12-05-2009, 11:24 PM   #5
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
yeah when it engages the other lights that increases the load on the system, and at the same time the RPMs are dropping considerably, you should see a serious drop in voltage. If you wanna be sure measure the voltage while this is occurring, you will see it go from as high as 16v to as low 12v, depending on the variance in your alt....
chongopants is offline   Reply With Quote
Old 12-05-2009, 11:27 PM   #6
Black Yaris
der Zeck
Black Yaris's Avatar
just take it to the dealership and tell them you have a concern, that is what a new car warranty is for
Old 12-06-2009, 02:53 AM   #7
ztlonewolf
ztlonewolf's Avatar
i appreciate all the help guys,definetly gonna take to the dealership,although i took the time to check it tonight and what is causing the lights to dim is the drop in rpm when i depress the clutch to stop,not the brake engaging,it drops below the idle speed and the ecm brings it back up,it just started doing this recently
Old 12-06-2009, 04:04 PM   #8
supmet
That's definitely the alternator going bad, and its not normal.
Old 12-06-2009, 05:09 PM   #9
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Definitely not normal. Could be the alternator, the battery or both. Unless it's still on warranty, get it checked at a proper auto electric shop where they can do a load test. If it is on warranty, the dealer is your friend.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 12-07-2009, 09:22 AM   #10
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
Try cleaning your battery cables. my alternator started whinning when it went bad cost $780.00 at the stealer
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 12-07-2009, 02:03 PM   #11
b_hickman11
Drives: 08 Sedan
Take it to the dealer ASAP since you are close to the 36,000 mile mark...Unless you have the extended warranty.
Old 12-16-2009, 05:42 AM   #12
ztlonewolf
ztlonewolf's Avatar
ok,i finally got it to the dealer,they ran a check on everything (so they say) and found nothing wrong,told me it was normal for the yaris to do that,which i find funny since it just started doing it about a month ago.
i would like to ask,anyone that has the time or thinks of it at the time,to check to see if your yaris does this,i have no mods,everything is stock and i'm usually just running the heater,radio,headlights(bright or dim) and the driving lights,thanx
Old 12-16-2009, 09:31 AM   #13
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I would take it to another dealer, that doesn't sound like normal behavior at all.
Old 12-16-2009, 01:33 PM   #14
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Buy a new battery, cheap insurance.
H E L P...Your Brother needs your help Plz! smartazawhipz General Yaris / Vitz Discussion 10 08-24-2009 02:59 AM
So I checked out an EVO VIII PETERPOOP Off-topic / Other Cars / Everything else Discussions 5 06-15-2009 05:17 AM
Checked out honda today for comparison..not impressed!! munchkin Canada 1 05-23-2009 08:06 PM
Has anyone checked with a paint shop to see if a clearcoat can be added...... grampi General Yaris / Vitz Discussion 36 07-24-2007 08:59 AM
What things should they have checked when I bought a new car? BMGYaris General Yaris / Vitz Discussion 2 11-02-2006 11:31 AM
