Old 12-15-2009, 06:41 PM   #1
plasticskis
Drives: 2008 Yaris
Air Filter
Had anyone had an issue replacing the air filter in an 08 Yaris? I opened it up, replaced with a Fram, and could not get it closed again. It looks like the edges pinch. I looked at the old one and the edges looked pinched also. I feel like it should go in easy, what am I missing?
Thanks in advance.
Bryan
plasticskis is offline   Reply With Quote
Old 12-15-2009, 08:10 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I put one in the old Echo and had a devil of a time getting the box closed.
Old 12-15-2009, 09:42 PM   #3
06silveryaris
Drives: 2006 yaris
That airbox is tricky the first time
06silveryaris is offline   Reply With Quote
Old 12-15-2009, 10:10 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^oh yeah, I thought I had gotten the wrong filter like 3 times once.
one of them (may have been a fram) had one edge that stuck out more that was not like the original.
Old 12-15-2009, 10:41 PM   #5
b_hickman11
Drives: 08 Sedan
You have to make sure the left side of the box locks into the tabs and then lower the right side of the box.
Old 12-18-2009, 01:30 PM   #6
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Another tip: place the filter in the upper half of the airbox first then bring the halves together. I found this to be much easier to avoid pinching.
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 12-21-2009, 02:39 PM   #7
TheSilkySmooth
TheSilkySmooth's Avatar
I put in a Wix, fit perfect, no problems - but I am a mechanic. The new filter seemed more restricted than the dirty one though!
Old 12-21-2009, 03:16 PM   #8
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Not all corners are the same-three are rounded and one is pointed. At least the factory one is-that was the only thing I figured out that made the top go back on right. If I remember correct the pointed corner goes in the left upper corner of the air box-the corner that's the hardest to see when holding up the cover and trying to put an airfilter in at the same time.
Old 12-21-2009, 09:51 PM   #9
deerebilt
Drives: 2008 Yaris sedan S
replaced mine with oem toyota fit perfect and was cheaper than name brand at autozone
deerebilt is offline   Reply With Quote
Old 12-21-2009, 10:19 PM   #10
supmet
Drives: 2007 4 Door Yaris
oxymoron??
You gotta push a little more than other cars, but mine snapped back in just fine with a K&N
Old 12-22-2009, 10:06 AM   #11
kingstonyaris
Drives: 08 liftback
I could not get an after market filter to fit--box would not close
Buy OEM box will close
kingstonyaris is offline   Reply With Quote
Old 12-22-2009, 12:09 PM   #12
b_hickman11
Drives: 08 Sedan
Mine closes fine with my K&N's on both Yarises
Old 12-22-2009, 01:04 PM   #13
Hershey
one corner of the filter is square , this goes in the upper left hand corner of the base of the air filter box . Then keep right side of upper box at about 40 degree angle and slip tabs of cover into slots of base . This is somewhat tricky . Make sure tabs are all the way in the slots for air tight fit . Hope I explained this ok , hard to put in words . GOOD LUCK .
Old 12-24-2009, 08:25 AM   #14
1stToyota
1stToyota's Avatar
My Beck Arnley filter fit like OEM, looks like it should flow better than the OEM egg carton
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 12-24-2009, 10:30 AM   #15
RedRide
RedRide's Avatar
Originally Posted by supmet View Post
oxymoron??
I had no trouble with a K&N either.
Old 12-25-2009, 03:09 AM   #16
fluke_boy
Drives: 2010 Yaris 3 dr hb
Note to self: they are talking about air filter not cabin filter.
fluke_boy is offline   Reply With Quote
Old 12-30-2009, 10:52 AM   #17
plasticskis
Drives: 2008 Yaris
Thanks all - does the sharp corner still pinch if I put it in the back-left?
Old 12-30-2009, 04:27 PM   #18
TheSilkySmooth
First: What does it look like, pleated paper instead of molded polyester fiber? I'm thinbking my wix, which looks like OEM doesnt flow too well - been having subtle performance issues ever since that wix air filter went in. It looked good though
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 100 06-20-2019 12:59 PM
