Old 12-15-2009, 07:53 PM   #1
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Custom Springs?
Has anyone found a place that will make custom springs. I want to go with Tokico HTS reds but the AOE TigetTec springs are the best I can find. I'd like a 2-2.5" drop with 6k(336lbs) front 5k(280lbs) rear. I know you may ask why not just get the TigerTec springs and deal with being a bit higher but, I'd like to see if the option is out there & I don't want to deal with replacing my suspension every year for winter with coilover (they corrode horribly in the winter with the salt on the road). I know kngrsll has been looking for stiffer springs too.
RacerFreakXXX is offline   Reply With Quote
Old 12-19-2009, 06:57 PM   #2
RacerFreakXXX
JDM Fred
I guess that's a no... I'm going to buy some AOE TigerTec's again and cut a coil out. Hopefully that should work the best.
Old 12-19-2009, 10:35 PM   #3
kngsrll found that Honda Fit springs will fit in the rear, I think he got 5k or 6k ones? sounds interesting.
Old 12-20-2009, 12:25 PM   #4
thepoche
thepoche's Avatar
Drives: Toyota Yaris CE
Would a standard 2.5x8 coilover springs fit? I think I'll try that when I get the chance.
I've done some rough calculations and with an 8in spring at a rate of 8k would give you 1.5 inch drop and 5k would give 2.1inch.
thepoche is offline   Reply With Quote
Old 12-20-2009, 02:33 PM   #5
kngrsll
Apexing Egg!!
kngrsll's Avatar
yeah, im using yaris tanabe DF210s up front and Fit rear springs from T1R, so 3kgF,6kgR. i would like the front a little stiffer, but the balance is pretty good. Currently, i am not using a rear sway bar. if you do the math, its worth about 150 lbs of rear spring.
i may look for some coilover sleeves for the front and get some eibach ERS springs. i like the split now, so if i get 5 or 6kg front springs, ill just put the rear sway bar back on. so, it would be 6kg front and rear plus a rear sway bar.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 12-21-2009, 12:49 AM   #6
RacerFreakXXX
JDM Fred
if that actually worked we could get a nice aggressive look wile still maintaining performance.
Old 12-21-2009, 02:11 AM   #7
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Yeah i just lost some more weight off my yaris and my cusco's are fully maxed out (full drop) and I still have about a 1.5" gap in the front . I was checking summit racing.com and for $60ish per spring eibach make 6"-10" long replacement coilover springs with spring rate from 250lbs/in - 1500 lbs/in. I'll be getting some 6" long with 500 lbs spring rate for the front to really get my ride low and stiff
Old 12-21-2009, 04:43 PM   #8
RacerFreakXXX
JDM Fred
I think a nice .5" gap would be nice for daily driving, do you know what spring size we would use (inside diameter)?
Old 12-21-2009, 07:47 PM   #9
blacksandiegovitz
Drives: 08 Vitz
Not sure what stock inside diameter is off-hand , but I can measure my stock springs(f/r) later when I go out to the garage .
Old 12-23-2009, 10:33 AM   #10
kngrsll
Apexing Egg!!
kngrsll's Avatar
im probably running a half inch up front and an inch in the rear. id actually prefer more like an inch all around. no one cares about how many turn fast goodies you have, if the suspension cant work properly.
Old 12-23-2009, 12:09 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
did anyone calculate wheel rate in this? lol
Old 12-23-2009, 12:13 PM   #12
Brentorius
Drives: 07 Mazda MX5 Copper Red
Stock spring inside diameter:
F - 2.5 in
R - 3.5 in
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 12-23-2009, 12:15 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
F - 2.5 in
R - 3.5 in
but they're not flat like a race spring.
Old 12-23-2009, 12:23 PM   #14
Brentorius
right; that is the end diameter.
Brent
Former Yaris Owner
Old 12-23-2009, 03:17 PM   #15
RacerFreakXXX
JDM Fred
can we use racing springs with tk reds or am i stuck cutting my some aoe tigertecs?
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Custom tags and custom vinyl ellenbetty Cosmetic Modifications (Exterior/Interior) 9 09-11-2009 03:13 PM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 06:32 PM
