#1 |
MY baby VIOS
Drives: Yaris Sedan Join Date: Dec 2009
Which method use higher fuel?
Does anyone know which method uses higher fuel during idling? Or all using same amount of fuel?
1. Put gear in neutral press on foot brake. 2. Gear in D, press on foot brake. 3. Put gear in park mode and hand brake/foot brake. |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
Transmission in D probably uses a little more, because the engine's connected through the torque converter to the wheels. Release the brakes and you'll roll off. Power's being expended. In either neutral or park, the engine's disengaged from the drive. I doubt you'll be able to tell any difference in practice. If you'd be spending a lot of time idling, it's better to shut the engine off.
#3 |
![]() ![]() Drives: 09 3dr (sold), 12 SE 5spd : ) Join Date: May 2009
Tranny in P?? That would be great if your moving and pull the break : )
Either way you sould not be moving. #1 or #2, no way for #3
Its all about the MPG's !! |
#4 |
All 3 are not moving. Why "no way for #3?" That makes no sense.
Your mileage is 0 in all of these cases, so extended stationary idling should be avoided, but it's a legitimate question as to whether the idling hourly fuel consumption is higher with the transmission engaged or not. |
#5 |
I said no way for #3 thinking that you can coast during idling for the #1 and 2.
But I guess this is not about MPG's, just about using gas in general. Maybe I dont really understand the question : )
#6 |
Is now a Corolla S Owner
I think the question assumes the car is stationary.
#7 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Having tested this out with the scangauge using the less amount of GPH (gallons per hour) is in neutral when stopped. The GPH does increase in drive with the brakes on.
#8 |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
A better question is when the hummer coming behind you isn't paying attention because they are on their phone and eating a big mac, which method will allow you to step on the gas and get out of the way the fastest. Well, maybe my scenario doesn't work in singapore, but the point is in neutral, park, or with the car off, you can't move quickly in an emergency situation, and you're saving 20 dollars tops if you keep the car 10 years.
#9 | |
#10 |
![]() Drives: 2009 Yaris 3 door Join Date: Sep 2009
Stepping on the gas won't do you much good if you're in a line of cars that are stopped.
Sure, there are situations where you might need to floor it quickly, but those situations are usually at red lights when you're the first car, and there's traffic crossing in front of you. So stepping on the gas to avoid being rear ended means increasing your chance of being hit from the side from another cheeseburger eating Hummer driver. Anyway, neutral definitely consumes less fuel than staying in drive. If it's a long light, turning the engine off uses the least fuel. |
#11 |
MY baby VIOS
Sorry all. I think my question posted making slightly confusion. The question is when at traffic light, Car engine ON and stationary.
Hi Astroman, Can scangauge tested on those 3 method? And What is the result shown? |
#12 |
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
#13 |
Modded Moderator
Yes, the scangauge can test all 3 methods. I've been using one for 2 years now and love it. As for the idle, the RPMs do increase when you put it in neutral vs. D with the brakes on BUT fuel consumption drops (GPH). It's not a little drop either, I average anywhere from .05-.2 gph difference depending on how long I've been driving, temperature, etc.
#14 | |
I always check the speed of approaching vehicles until I've got a car or two behind me, especially when riding the motorcycle. |
#15 |
![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
I dunno about you, but I've honked my horn at people when they were getting dangerously close to my car, and the only reaction I received was that they got even closer. Like they couldn't hear the horn or something. It is a rather underpowered horn, and if the person is in their Hummer (or other vehicle), windows up, talking on the phone or playing the radio loudly, chances are they won't hear it either. Unfortunately.
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!! ![]() |
#16 | |
But I've certainly had to do it more than once on the Harley ... it's true that people do tend to look right through motorcycles. I did have a lady rear end my Wrangler once. Luckily, most of the damage was to the hitch mounted bike rack and her car. But ever since I've always payed closer attention to approaching vehicles. |
#17 |
3 or 2
#18 |
The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
Higher octane fuel | frailer | General Yaris / Vitz Discussion | 23 | 02-26-2009 08:54 AM |
Facts of Higher Fuel Octane | Yaris TTE JWRC | General Yaris / Vitz Discussion | 9 | 01-29-2007 07:16 PM |
