Old 12-18-2009, 09:32 AM   #1
amtoro
amtoro's Avatar
Drives: 2009 3LB Metheorite
Question Coil springs "brackets" anyone?
I have been trying to come up with an inexpensive way to modify the suspension on my LB and saw these brackets at the parts store. It says you can use them to raise or lower the vehicle and I wonder if besides the plus of lowering the center of gravity it would stiffen the springs a bit as it virtually removes one turn off the springs.
Could I do this and install an anti-sway bar and get good results? or should I definitely buy performance springs if I want to notice any difference?
Thanks
amtoro is offline   Reply With Quote
Old 12-18-2009, 01:01 PM   #2
ddongbap
LOL.
Old 12-18-2009, 01:21 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
the old rule of thumb you get what you pay for applies heavily to this thread.
save up, buy the right stuff, and drive in confidence, knowing that one of those brackets isn't gonna break on you and destroy something driveline related.
Old 12-18-2009, 02:54 PM   #4
amtoro
amtoro's Avatar
Thank you, I was just curious about those things. I'll start with the 23mm sway bar and see what else from there.
Old 12-18-2009, 03:15 PM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Ahem...
Just because it doesn't cost a ton of money doesn't mean it won't be effective.
I've never used those, but I HAVE used the rubber donut spacers that effectively do the same thing. YES, if you remove a coil from the equation (by physically cutting a coil from the end of the spring, or by immobilizing any coil in the spring) the spring rate DOES increase. If you have all the dimensions of the spring (wire diameter, diameter of coils and number of coils), you can even calculate how much the rate increases.
Don't be snobs, guys. A set of these on the rear springs with a rear swaybar could do wonders for the handling of an otherwise stock Yaris.
That said... I'd probably opt for the donut spacers. They're less likely to fall out, and they're not going to bend or break.
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Lowering Springs vs Coil overs BatMobile Wheels, Tires and Suspension Forum sponsored by The Tire Rack 42 09-25-2009 06:55 PM
coil over or springs. new or used. 3dr lb etheliters Willing to Buy by private party 0 07-27-2009 04:32 PM
