Old 12-18-2009, 10:28 AM   #1
bored@work
Car Squeals when started
I just recently got the belt changed and my car is still squealing really bad. Does anyone know what else could be the problem? it's a 2007
bored@work is offline   Reply With Quote
Old 12-18-2009, 10:40 AM   #2
amtoro
amtoro's Avatar
Drives: 2009 3LB Metheorite
The belt might need to be re-tightened, or it could be wet due to condensation in the mornings, or it might not be gripping to the pulley correctly; in the later, my father used to rub a chunk of bee's wax on the belt's contact surface (the "V" shaped side) and it would stop it for some time.
amtoro is offline   Reply With Quote
Old 12-18-2009, 10:49 AM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Water pump or alternator bearing?
Old 12-18-2009, 01:03 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
When you put on a brand new belt the rubber is new. It will stretch slightly over the new few days. If it was installed slightly loose to begin with that would explain the squeeling now. Have it taken back and retightend.
Old 12-18-2009, 01:25 PM   #5
DerFlosser
DerFlosser's Avatar
Agreed....they probably put it on too loose and really...no excuse for that and an inconvenince for you.
DerFlosser is offline   Reply With Quote
Old 12-18-2009, 06:34 PM   #6
Cutie Pie #2
Drives: 2014 Honda CR-V LX
Mine just started squeeking along with a kind of a chirping noise only when you first start the car in the morning mostly when you put on the defroster. It goes away after a few minutes and all is fine. Is this the start of something going bad. I have not had any service done on the belts yet, I have 34K miles on the car. Any suggestions?
Cutie Pie #2 is offline   Reply With Quote
Old 12-18-2009, 07:18 PM   #7
YarisSedan
Could just be a loose or worn belt. Especially if only in the morning and then goes away.
Old 12-18-2009, 09:42 PM   #8
yaris9876
Drives: yaris hatch 07 640K original m
i didnt change my original until 170K. it was squealing and now there is a bearing squeal that is impossible to pin down because they crammed alternator, tensioner, and water pump right on top of each other.
how the hell can you tell what it is.
yaris9876 is offline   Reply With Quote
Old 12-27-2009, 12:14 PM   #9
Sidicas
Drives: 2010 Toyota Yaris Hatchback
Holy cow! The Yaris doesn't have an automatic tensioner???
I find that very surprising.. Well, I guess on the flip side of it, you don't need to pay $350 to have the automatic tensioner replaced every 5 years.
Learn something new everyday..
Sidicas is offline   Reply With Quote
Old 01-07-2010, 06:47 PM   #10
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I had this problem, went back to the place and they tightened it and never squeaked again.
Ron
198K Miles
N9QGS is offline   Reply With Quote
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
