Old 12-19-2009, 07:47 AM   #1
piwko4
Drives: 09 3dr 5spd
5000mi Maintnence?
Comeing up on 5000mi.. Is the sch maintnence covered by the warranty ?
piwko4 is offline   Reply With Quote
Old 12-19-2009, 09:40 AM   #2
chai
Go Duke!
Drives: '09 Sedan AT
The oil change and tire rotation is not. Anything else they find that is faulty should be replaced under warranty. They may try to upsell you on useless stuff like wheel alignment (should be aligned from factory...), just tell them if they want to fix something to fix it under warranty.
I got a tire rotation at the dealership here for $19 to test their services. While they seem decent I decided I would do as much of the maintenance myself as possible. I'm not quite at 5K but I changed the oil myself and just put on snow tires, so tire rotation was wasted
If you have the aptitude... do it yourself and you will be sure it's done right. If not, make sure you aren't robbed.
chai is offline   Reply With Quote
Old 12-19-2009, 10:24 AM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
All that needs doing, really, is the oil change and tire rotation. Routine maintenance isn't covered by warranty.
