Old 12-21-2009, 09:06 AM   #1
nerisahzn
Drives: Yaris T3
Fuel Gauge Stoped Working
Hi guys. My fuel gauge stopped working and is stuck at 1/4 way. is there any fuse that controls this or is there something wrong in the tank. pls help thanks.
nerisahzn is offline   Reply With Quote
Old 12-21-2009, 09:18 AM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
dont know about your model, but I believe our fuel gauge is controlled directly from the fuel level gauge in the tank.
Old 12-21-2009, 10:37 AM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
If you've got the digital gauge with the LCD bars as most of us do, it's pretty much got to be a bad sensor in the tank.
Old 12-21-2009, 12:32 PM   #4
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
I've had the tank unit replaced twice now, and it's gone again. DO NOT depend on the tank gauge! Use your trip odo, and you won't be left stranded out there...
Old 12-21-2009, 01:15 PM   #5
When the sender is disconnected (i.e. if the fuse was popped), the bottom bar flashes rapidly, like you are about to run out. The fuel gauge sender is just a rheostat that is monitored by the combination meter. You may want to pull it out and check the sender rheostat for build-up from impurities in the fuel.
When I pulled Crashy's fuel tank off to do some frame welding, I pulled the sender out of the tank to check it out. Here are some pictures of it:
Old 12-21-2009, 01:49 PM   #6
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
yeah i never trust fuel gauges, the last bar starts blinking, i should have 1.4 or something gallons, then drops to 1.1 or something when fast blinking, but i fill up when it starts blinking, i never break 10gals at pump. the bars drop too fast i guess. better to be safe than sorry and fill up when it blinks tho.
Check out my Build thread:
Old 12-22-2009, 04:32 AM   #7
nerisahzn
Drives: Yaris T3
thanks guys, will get the hubby to check the tank. thanks a lot for the help.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
