Old 01-10-2010, 02:56 AM   #1
Nas_RS
Vitz_RS
Drives: Toyota Vitz RS NCP91
Engine Mounting
Hello,
Anyone know to check the Engine mounting support, if is ok or broken..
what is the negative effect you get when it is damage
Nas_RS is offline   Reply With Quote
Old 01-10-2010, 03:31 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I would think that you would have problems with your CV joint or axle before the engine mount. You would hear a clunk sound when engaging the clutch or shifting.
Old 01-10-2010, 03:57 AM   #3
Nas_RS
Vitz_RS
its not when shifting, i get the clunk sound when holding the acceleration on first or second shift..like a knocking sound, sometime doesnt get it when fast shifting of first and second shift
Old 01-16-2010, 01:38 AM   #4
Nas_RS
Vitz_RS
anyone know part number of the engine mounting rear, left and upper..
for toyota vitz rs 1.5 NCP91
Old 01-16-2010, 02:09 AM   #5
YarisSedan
Drives: 08 Yaris Sedan
I get the same sound. Our cars dont have a front engine mount like 99 percent of all the other cars on the market. I supose to save cost and i guess they figured a economy car with small power engine wont have that much torque. But quick shifts will make the engine jerk a bit.
You can get a nitto torque dampner which does help a bit or a stiffer rear mount such as trd or a solid one.
Old 01-16-2010, 02:17 AM   #6
Nas_RS
Vitz_RS
yes you right, we dont have front engine mount.
mine rear one is damage, do you know where i can order it.
Old 01-16-2010, 02:23 AM   #7
the rear one is underneath, also called the trans mount or "dogbone".
In the engine bay are the left and right engine mounts.
Please describe the damage, there's not much that can go wrong with that.
Old 01-16-2010, 02:32 AM   #8
Nas_RS
Vitz_RS
Thanks for the help, do you know where to order or the part number of the 3 mount kit
Old 01-16-2010, 03:12 AM   #9
goku87
goku87's Avatar
Drives: Black HB
Not sure if this helps:
http://www.partstrain.com/store/inde...Engine%20Mount
Old 01-16-2010, 03:44 AM   #10
YarisSedan
Looks like its time to order a trd one from garm then
Old 01-16-2010, 04:27 AM   #11
Nas_RS
Vitz_RS
yes TRD much better and torque, anyone know where to order online
Old 01-16-2010, 04:28 AM   #12
Nas_RS
Vitz_RS
diagram engine mount
http://www.toyodiy.com/parts/p_J_200...HMVK_1107.html
Old 01-19-2010, 09:27 AM   #13
YaYa1320
YaYa
YaYa1320's Avatar
I just filled the voids in the "dogbone" mount with 3M window weld. It cut down on the movement ALOT, and it was 18 bucks for the tube @ pep boys.
YaYa1320 is offline   Reply With Quote
Old 01-19-2010, 05:26 PM   #14
YarisSedan
Yeah but how bad is the vibration.
Old 01-19-2010, 05:28 PM   #15
shouldn't be too bad. The TRD one is harder rubber than stock, and it doesn't add much to the noise in the cabin.
Old 01-20-2010, 07:12 AM   #16
YaYa1320
YaYa
YaYa1320's Avatar
Not bad at all. I have always used stiff inserts in honda mounts for years, and the vibration in the Yaris with the window weld in the mount is not noticeable to me, but the engine movement is greatly reduced. I could feel the engine rocking back and forth before I did this, now I dont feel it rocking. I like it
