Old 01-12-2010, 05:31 PM   #1
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Powering/Installing Tweeters?
I dont know much about installing tweeters, but I really want some better highs now. I understand they come with crossovers to play the correct frequencies. Though thats not what powers them (right?) and I wanna know what you guys usually do when installing tweeters. Currently I have this amp to power the 2 front speakers and 2 rear speakers in the car:
KICKER ZX200.4 CAR STEREO 200 WATT 4CH AMP AMPLIFIER
Thus all spots are taken on the amp. I am currently just planning on using the 2 front speaker wires from my HU (Alpine iDA-X100 - http://www.crutchfield.com/p_500IDAX...ures_and_specs) for the tweeters, but I'm thinking that wouldnt balance out with the amped speakers and sub I am running. Do you guys usually buy an amp for tweeters, or do get amps that have the feature to connect tweeters+speakers+subs+etc (if it exist).
Considering some low level entry tweeters from crutchfield if that makes any difference. Any other info needed will be provided on request
Thxthx
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 01-12-2010, 09:00 PM   #2
r3b3l
r3b3l's Avatar
Drives: 2010 Yaris 3dr liftback
If you bought a kicker component set it should have come with two passive crossovers. one for each side. you would plug your front mids as well as the highs(tweeters) into the passive crossover. The amp wire to the fronts should go into the passive crossover and then distribute the power to the speakers.
r3b3l is offline   Reply With Quote
Best place to mount tweeters in the LB? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 20 01-18-2010 11:45 PM
Anyone with OEM tweeters integration in A-Pillars ? (SEDAN) mledez In Car Entertainment + Electronics (audio / video / alarm) 10 12-18-2008 11:36 AM
A-Pillar gauge pods that can fit tweeters? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 9 11-23-2008 02:25 PM
F/S RE Audio XXX 6.5c Component set w/ Tweeters dlinkwit27 Items for Sale by private party 16 11-10-2008 01:18 AM
Install of tweeters in the rear???? jdubau55 In Car Entertainment + Electronics (audio / video / alarm) 54 03-09-2007 07:44 AM
