Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 01-19-2010, 05:49 AM   #1
Carolyn
Drives: Toyota Yaris
Door latch removal
Hi - How do you remove the driver's door latch on my daughter's 2004 Yaris? The cable has broken between the inner door opener and the latch. I have removed the door panel, undone 3 screws and a bolt securing the latch. Now the latch is only attached by the outer door handle lift rod. How can I detach this from the door latch? Many Thanks Carl.
Carolyn is offline   Reply With Quote
Old 01-20-2010, 07:11 PM   #2
DaveJohnCrowley
I have the same problem. only happened to me today if you have found the solution can you let me know.
Cheers
DaveJohnCrowley is offline   Reply With Quote
Old 01-21-2010, 12:21 AM   #3
Name:  04 Door Handle.jpg
Old 08-03-2012, 05:26 PM   #4
new-yaris-owner
Drives: Toyota Yaris LE HB 2008
Old thread resurrection !
Is this all I need to know if I want to replace the driver's door latch ? I know how to remove the inside panel... I will see what stuck me tomorrow when I will install it.
Many thanks!
new-yaris-owner is offline   Reply With Quote
Old 10-31-2013, 05:52 AM   #5
madcat
Drives: Toyota Yaris, 2004, 2 doors
Another resurrection, exactly the same problem! How do i find out the exact product code for the replacement cable? I want to make sure I get the right one for a 2004 Yaris, 2 door version.
madcat is offline   Reply With Quote
Old 10-31-2013, 08:58 AM   #6
There are a few variations for your French made Yaris. PM me your VIN and I can tell you exactly which one is used on your car.
Old 11-01-2013, 10:36 AM   #7
04 EU yaris uses rods.
Old 11-01-2013, 10:50 AM   #8
Correct - Rods for the locks, but still cables for the inside door handle (which is what I believe the OP is looking for).
Old 11-01-2013, 03:37 PM   #9
You are right.. cable from the handle
DIY for Steering Wheel/Airbag Removal? MGargano DIY / Maintenance / Service 5 03-01-2019 02:21 AM
Paintless Dent Removal - Dent Magician Chupacabra General Yaris / Vitz Discussion 3 01-27-2009 10:07 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
