Old 01-21-2010, 12:38 PM   #1
BassAssassin
Drives: 2008 Yaris Sedan 5MT
Driver's Seat Height
Does anyone know if there is a way to lower the stock driver's seat height by removing the slider and mounting the seat directly to the floor? Obviously, I'd lose the ability to adjust the seat forward or backward.
BassAssassin is offline   Reply With Quote
Old 01-21-2010, 12:46 PM   #2
Haven't heard anyone try that! This would take some customizing or fabricating, take a look at the angles of the brackets that bolt to the floor.
You would also have to attend to the airbag sensor that notes the position of your seat.
Old 01-21-2010, 01:03 PM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
This spring I may start working with a local fab shop on a Yaris seat-lowering solution. I'll post if/when this happens.
In the interim, if you don't mind losing adjustability, I'd imagine you'd be able to bolt the OEM seat to the floor with a simple bracket.
Old 01-21-2010, 08:05 PM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
get aftermarket buckets with new brackets, i believe megan makes the brackets.
Old 01-22-2010, 08:32 AM   #5
YaYa1320
YaYa
YaYa1320's Avatar
I put aftermarket seats (Sparco) on the stock rails and sliders using flat metal to make brackets. All u need is a drill, hacksaw and a tape measure and it can be done. The seats sit about 3 inches lower, you could raise them up with washers, but Im 6'4, so I love sitting lower. There are some old threads on here with pics, thats where I got the idea. DO NOT get the Weapon R seat brackets!!! THEY ARE JUNK AND SIT WAY HIGHER THAN STOCK!!!
YaYa1320 is offline   Reply With Quote
Old 01-22-2010, 08:36 AM   #6
YaYa1320
YaYa
YaYa1320's Avatar
Oh, anybody wanna buy some Weapon R seat brackets??? Haha!!! $40.00 shipped!!! Oh, the airbag sensor can be adressed with a bypass module, PM CTScott, he makes them, I bought one, it wotks flawlessly
Lower Seat Height? BassAssassin Cosmetic Modifications (Exterior/Interior) 47 02-25-2010 10:14 AM
Complete Racing Seat Install Guide advocate DIY / Maintenance / Service 7 11-25-2009 02:26 AM
Having my stock driver's seat custom-fitted and stiffened 427chev General Yaris / Vitz Discussion 4 03-23-2009 09:22 PM
Fabric Wear On Driver's Seat Darth Gilbert General Yaris / Vitz Discussion 18 04-28-2007 07:13 AM
