Old 01-31-2010, 01:17 AM   #1
Dec24th
Drives: '10 Yaris 3 door HB
Dehumidifiers
I just ordered this item from Amazon, a dehumidifier. http://www.amazon.com/Eva-dry-Renewa...pr_product_top
With mostly positive reviews on Amazon, I proceeded to buy the product in hopes of it working inside my Yaris.
Has anyone else used a similar product for their car with satisfying results?
Dec24th is offline   Reply With Quote
Old 01-31-2010, 01:18 AM   #2
YAR1S
YAR1S's Avatar
hmmm I need one of those after all this snow. I always have fogged up windows its so annoying.... cant wait for summer to dry out my car.
-Jen <3
Old 01-31-2010, 01:28 AM   #3
Dec24th
That's why I bought it, to relieve the fogging abuse on my windows.
Old 01-31-2010, 09:29 AM   #4
Sidicas
Drives: 2010 Toyota Yaris Hatchback
Winter air is usually much drier than summer air.. As long as you're not recirculating you should be pulling plenty of dry air into the car..
Just keep the blower on "3" constantly and you should be fine.. Point your side vents to your windows. No problems with interior fogging here in NY..
Part of the reason why windows fog is because the windows are so cold and the air hitting them is much warmer and moist from your breath.. Point your vents to the windows, warm up the windows and you get no fog..
Sidicas is offline   Reply With Quote
Old 01-31-2010, 10:13 AM   #5
MadMax
MadMax's Avatar
I don't think that little think is going to do jack in your Yaris, it is not designed for use in automobiles. It is meant for use in closets and whatnot ("small enclosed areas") where it can function on a slow, steady basis. Honestly, you're gonna need something more serious, which is why the capacity to defrost and dehumidify your car is built into the a/c unit...
Old 01-31-2010, 10:30 AM   #6
127.0.0.1
if your yaris has AC, that is your dehumidifier
crank the ac, use outside air, and it will dry out the car
Old 01-31-2010, 10:51 AM   #7
Kongo-Otto
Drives: '09 Yaris & '10 Auris
