Old 02-05-2010, 08:15 PM   #1
LA Yaris
Yaris323
LA Yaris's Avatar
Thinking about buying LED Light bulbs and Projector head lamp
I was just wondering if anyone on here has bought these lights??
If so do they work well ?? Or do you have to do some MOD. ??
I wonder if Garm can get these for me ??
Old 02-05-2010, 08:22 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Me personally i dont like led bulbs in our housing cause it dosnt illuminate the area even with the leds scattered around liek in the picture. If you look at true led tail lights they have many many many leds in a cluster to get the same effect one single regular bulb could illuminate because they only light in a strait beam pattern.
If you put those also in the turn signals you will get that fast blinking effect as if you had a burnt out bulb. Worthwhile leds would be the license plate light bulbs since they are pointed strait down anyways. Or dome light leds that come in a mini cluster. Or trunk leds. I have all of those installed already.
Old 02-05-2010, 08:29 PM   #3
LA Yaris
Yaris323
LA Yaris's Avatar
If you put those also in the turn signals you will get that flas blinking effect as if you had a burnt out bulb. Worthwhile leds would be the license plate light bulbs since they are pointed strait down anyways. Or dome light leds that come in a mini cluster. Or trunk leds. I have all of those installed already.
I know what you mean about the turn signals. I just wish they had some LED'S taillights for the Sedan. I know Garm has them but maybe I will get them when I get my tex return.. I do have the LED'S for the license plate.
Old 02-05-2010, 09:05 PM   #4
LA Yaris
Yaris323
LA Yaris's Avatar
I know I would buy these if I new were to get them at ??
I wonder if Garm can Order them
Old 02-05-2010, 10:04 PM   #5
I have those headlights (those in that pic is installed upside down, btw). They're bolt-on HID projectors.
Awesome mod. Garm is getting the G2 or G3 in stock (which are supposedly better than the G1, which I have and the one in that pic). It'll be like $120 more, so it's up to you if you want to spend that much. They're a great alternative to an actual retrofit, but don't expect to outshine most OEM projector HID's out there.
Old 02-05-2010, 10:08 PM   #6
YAR1S
YAR1S's Avatar
DIY :
http://shop.microimageonline.com/Pro...-H4-prj-h4.htm
OR
PAY A LOT: http://depoautolights.com/headlights...abf342d2289120
I think these are them.... im not entirely sure....go to the link or maybe they are under yaris? here.
-Jen <3
Old 02-06-2010, 09:04 AM   #7
Brian
Brian's Avatar
I'm pretty sure those are the RHD version. Just do the retrofit. It's a lot cheaper.
Old 02-06-2010, 12:41 PM   #8
Altezza
Series 5
Old 02-06-2010, 12:41 PM   #9
to answer the question, yes I can get these:
Old 02-06-2010, 12:44 PM   #10
I think this style has no side turn signals, so it's illegal at least in California. Buyer's choice on that detail of course.
Old 02-06-2010, 06:05 PM   #11
LA Yaris
Yaris323
LA Yaris's Avatar
How much are these Garm ??
Old 02-06-2010, 06:07 PM   #12
LA Yaris
Yaris323
LA Yaris's Avatar
Altezza
Series 5
After tax return I will get the Series 5
Old 02-06-2010, 06:11 PM   #13
LA Yaris
Yaris323
LA Yaris's Avatar
Garm have you seen the OEM with LED'S Tail light ?? It looks just like the OEM one just the Red part has LED'S. Can't find a pic. But i know Hella makes them.
Old 02-07-2010, 04:36 AM   #14
Lucas13
Drives: 07 Yaris LB
This type of LED'S are called SMD I have them in my taillights, foglights, parking lights and license plate, they look great, SMD led’s spread the light at an angle of 180°.
Lucas13 is offline   Reply With Quote
Old 02-07-2010, 01:51 PM   #15
YarisSedan
Daamn how much would those rstyle racing ones run
Old 02-07-2010, 03:12 PM   #16
^ it'll be far more cheaper to just buy the bolt-on projectors and DIY.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
LED Headlight City Light Bulbs Treyz Cosmetic Modifications (Exterior/Interior) 16 10-10-2009 08:05 PM
