Old 02-06-2010, 02:41 PM   #1
yaris prime
Yes- I fit in it.
yaris prime's Avatar
Drives: 2007 Yaris liftback, MT
Issue when starting..
I have had this happen a few times. I turn the key to start the car and it is almost as if the car "half starts." It is running, but seems as if it is severely missing and the starter is still cranking. If I shut it back off and then start it again, it is fine. Again, this has only happened a few times. Any ideas?
I'm surprised it doesn't have a pull-start !
yaris prime is offline   Reply With Quote
Old 02-06-2010, 08:37 PM   #2
OtownYaris
OtownYaris's Avatar
Drives: Meteorite Yaris Liftback
Send a message via AIM to OtownYaris Send a message via Yahoo to OtownYaris
Sometimes out of the blue my Yaris will crank for a long time with my hand off the key until it finally starts and sound kind of odd at first. Then, after that starting up is fine. Not sure if it's the same issue you are talking about but it has been doing it for the past 3 years on rare occasions and it's been 100% reliable.
OtownYaris is offline   Reply With Quote
Old 02-06-2010, 10:12 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
A few times when my car didn't start immediately, and it continued to crank all by itself until it started! Interesting feature.
Old 02-06-2010, 10:28 PM   #4
auxmike
auxmike's Avatar
Yeah, you just twist the key and let go right away and the car self cranks itself.
I thought something was wrong with the car when I first got it.
Then I wondered why there was such a huge delay between stepping on the gas and the car actually moving.
I hate drive by wire....
Old 02-06-2010, 10:32 PM   #5
krusty
krusty's Avatar
Drives: 2010 Yaris ce
the 010 drive by wire seems to be way better then the 08's if you try a throttle control it would help with the throttle response
krusty is offline   Reply With Quote
Old 02-06-2010, 10:36 PM   #6
krusty
krusty's Avatar
the starting issue any mods to your car?
Old 02-06-2010, 11:21 PM   #7
Dec24th
Drives: '10 Yaris 3 door HB
I learned this week by accident that a quick turn of the key starts the car. nice feature for sure
Dec24th is offline   Reply With Quote
Old 02-07-2010, 01:24 AM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You might want to run a fuel system cleaner.
Old 02-07-2010, 01:29 PM   #9
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
There was a long thread about this last year, and as I recall several folks said they'd fixed the problem by holding the key turned to the start position till it started, and NOT just quickly blipping it over to start and back to run, letting the computer handle it. Try searching the archives.
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
