#1 |
its EF LB 55
Drives: Toyota Yaris 2007 Sedan (US) Join Date: Sep 2006
Aftermarket High-output Alternators
Ok, so I've been given advice to get an alternator for a current 1200 watt sound system that I plan to go to about 1600 watt and add some more devices into my car. First of all, are there aftermarket alternators for the yaris? I went to my dealership and they said neither toyota or jdm makes anything for it yet. Also, how much more power will i get if i upgrade to an optima red-top battery?
thanks |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
In this case where a larger alternator is not available you could add a second alternator or have the OEN re-wound for more power by a custom chop.
Adding a second alternator may require a bit of fabication to make a second Alt bracket. Where having the alternator rewound is as simple as buying a new alternator and sending it to a shop to be rewound. But with that much power you would be very wise to run auxillary batterys with an isolator set up. Even if they are fairly small batteries. This way they charge when the car runs but will not draw a charge off the main battery.
The early bird gets the worm, but the second mouse gets the cheese. |
| Toyota AUX plug w/ aftermarket radio? | eight_heads | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 09-07-2007 02:41 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
