Old 02-12-2010, 03:18 PM   #1
cdydjded
Drives: Yaris LB Turbo
Phantom Grip LSD
Im inquiering with Phantom Grip to see if they can produce a unit for the Yaris. I would like some feedback on the interest of this product. Please, if you have never used or installed this product personally, do not critisize it. I know it works, Iv used & installed it myself. It retails for $299. It is a good alternative for a Kaaz/TRD/Cuzco LSD unit which are in the $600-$700 price range. Here is there website if you want to learn more about it: http://www.phantomgrip.com/
cdydjded is offline   Reply With Quote
Old 02-12-2010, 06:03 PM   #2
90tsi
90tsi's Avatar
Drives: 09 yaris
i had this in my 90 talon. it felt like more of a locker than an actually lsd to me. But for the money it is a great alternative. i would get another one for sure if i had the cash
90tsi is offline   Reply With Quote
Old 02-12-2010, 06:20 PM   #3
good alternative for the money. They weren't going to make one for us when we contacted them over a year ago.
Old 02-12-2010, 08:08 PM   #4
cdydjded
Spoke to the owner today, they have a unit already for the Yaris which also fits the xA/xB & Echo. Im making an apointment with them to get the Phantom Grip installed along with a Clutch Masters Stg 1 & possibly a flywheel. We are planning to take photos & videos of the installation. Also before & after results on the 1/4 mile.
Old 02-12-2010, 08:16 PM   #5
How does it work?
Old 02-12-2010, 08:37 PM   #6
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
Over the years I have always wondered if this would work on an automatic transmission. If not, guess I will have to swap to manual.
Old 02-12-2010, 08:38 PM   #7
90tsi
90tsi's Avatar
Drives: 09 yaris
its not complicated at all kinda simple idea.. the 2 pieces have springs between which applies force outward to both side of the gears if i remember correct.
Old 02-12-2010, 09:09 PM   #8
cdydjded
The PG is install in between the spider gears of the differencial. All transmissions have a differencial, manuals & automatics. So yes it will work.......
Old 02-12-2010, 09:11 PM   #9
cdydjded
How does it work?
The PG locks the spider gears which in turn transfer traction to both tires instead of one.
Old 02-13-2010, 02:49 AM   #10
Is this constant, or variable based on load?
Old 02-13-2010, 02:50 AM   #11
90tsi
90tsi's Avatar
Drives: 09 yaris
from what i felt in my last car it was a constant.
Old 02-13-2010, 03:27 PM   #12
kngrsll
Apexing Egg!!
kngrsll's Avatar
i have never heard a good thing about the phantom grip.
that being said, for that much work, why not install a REAL LSD. There are so many good cheap units on ebay, its ridiculous. i got a 2 way clutch LSD for under $500 from a toyota starlet turbo, this thing is awesome
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 02-14-2010, 12:34 PM   #13
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
PG is a constant and honestly by the time you take everything apart to install you may as well of installed the TRD unit which unless you are turning some serious power is not gonna break before the axles do.
There are a few guys that have put the PG in their xA/xB and ended up with it breaking.
Old 02-16-2010, 11:29 AM   #14
d1nzfe
Drives: 1NZ-FE
can we fit in a obx lsd for 4age ? its selling for <$300.
d1nzfe is offline   Reply With Quote
Old 02-16-2010, 11:39 AM   #15
i have a friend who's had a pg lsd in his matrix xrs for years now....and now he's supercharged....he's never had a problem with it.
only problem he's had is he eats thru tires.
you see, the PG "LSD" basically locks the differential so that both wheels turn at the same rate. great in a straight line, but obviously, when you turn the outside wheel is travelling farther than the inside wheel so the inside wheel will hop a bit, and thus wear out more quickly. he goes thru a pair of tires every season, iirc.
i don't think id recommend it for the yaris since its a car meant for the corners....
Old 02-16-2010, 01:52 PM   #16
I am reading about some failures on the internet. Some of these are probably because people didn't know what they were doing when they installed the unit. But some might be because the PG is just plain rough on the tranny.
Old 02-16-2010, 06:53 PM   #17
kngrsll
Apexing Egg!!
kngrsll's Avatar
I have no personal experience so i couldnt say one way or another. I know on the 240 forums, everyone hated them and they never had a good thing to say. Saying that, the 240 was extremely sensitive to an LSD. The S15 helical unit i installed transformed my car, it was soooo good after i installed it, so good in fact, that i oil starved my engine at an autox due to the increase in cornering speeds and grip :(
I think if you want a diff that just locks for drag racing, maybe this thing is fine. if you want it for going faster at autox or track days, id shy away from it. especially, for all that work and money, for a bit more, you can get a really great proven LSD on ebay.
Old 01-31-2011, 10:22 PM   #18
how is the pg lsd and your tires holding up?
TRD 2 way clutch LSD kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-05-2009 11:59 AM
Anyone installed an LSD in their Yaris? Keith Tinari Performance Modifications 15 08-01-2009 11:54 AM
LSD Question PHXDEMON Performance Modifications 14 05-04-2009 10:58 PM
TRD Helical LSD kngrsll Items for Sale by private party 18 04-27-2009 11:16 AM
Is LSD Automatic & Manual Same? maxgil05 Performance Modifications 4 04-24-2009 10:57 AM
