Old 02-13-2010, 03:46 PM   #1
yaris-one
Drives: 09 sedan, stock....for now
i.....am.......confused......
so i get the front sway bar, ordering the rear soon, i install it, and no troubles
drive the car to work, fine, handles a little better, i like it so far
on my way home i take a left turn at a decently high speed, im not drifting or anything, just hugging the corner a little. well my check engine light starts blinking, so i back of the throttle, turn my music off and listen, it stops blinking and stays off....i pop the hood take a look, everything looks fine.
next day, same corner, same speed, same blinking, but this time it stays on, get home, turn car off, pop hood, nothing seems wrong, check fluids and electrical connections, all good, check engine light still on..........suggestions
im going to call a repair shop on monday, but id like to try and figure the problem myself before i have to drop a bunch of cash, its very frustrating when i go to work, fix multimillion dollar aircraft and my yaris confuses me...lol
yaris-one is offline   Reply With Quote
Old 02-13-2010, 04:05 PM   #2
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
check engine or service maintenance?
Old 02-13-2010, 05:54 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Maybe knocked a connector slightly loose and the forces of the curve are enough to break contact?
Old 02-13-2010, 08:04 PM   #4
YAR1S
YAR1S's Avatar
LOL. I'd laugh so hard if this was it.
-Jen <3
Old 02-13-2010, 11:26 PM   #5
auxmike
auxmike's Avatar
If you had the Scanguage II.........
Old 02-14-2010, 12:17 AM   #6
Dave
Drives: 2007 Yaris Sedan
I thought flashing CE lights were typical of misfire problems.
Dave is offline   Reply With Quote
Old 02-14-2010, 12:29 AM   #7
^ yes - blinking CEL is not good, definitely not related to maintenance required. if both came on, you might have an electrical problem.
why not take it to the dealership? are you out of warranty?
where did you get your front sway bar?
Old 02-14-2010, 03:01 AM   #8
yaris-one
no its not maint reqd, just changed the oil in fact.
no main reqd light at all, CE light started blinking in the curve, and for a couple secs afterwards, then stayed solid.....not out of warranty, was just trying to figure it out on my own for now.
whats a scangauge II?
and i got the strut bar from micro. figured it might have been some kind of shorting problem considering its mounted almost directly over the battery contacts.
Old 02-14-2010, 05:28 AM   #9
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
An 09 has to be still under warranty,let the dealer figure it out. A Scan gauge is an onboard engine computer..http://www.scangauge.com/
Old 02-15-2010, 12:39 PM   #10
ryota
Dry Bones
ryota's Avatar
Drives: 2008 Yaris Liftback
Send a message via AIM to ryota
if you don't want to spend the cash on a scanguage II you can also go to an advanced auto or other auto parts store and they usually have a code reader that they will let you use for free... it came in handy with my old car a few times
Ryota
ryota is offline   Reply With Quote
Old 02-16-2010, 09:10 PM   #11
yaris-one
Ok im gonna go to autozone but where do I connect the code reader at? I have an 09 sedan.
Old 02-17-2010, 03:09 AM   #12
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
On the lower left side of the dash, there is a compartment. Remove the compartment and behind is the OBD II connector.
Old 02-17-2010, 07:06 AM   #13
jambo101
jambo101's Avatar
Actually if you look underneath that compartment the OBD11 connector is pointing straight down,no need to remove the compartment door..
Old 02-25-2010, 07:56 AM   #14
41magmag41
Drives: Loaded 2007 mica silver sedan
Just a thought, when you changed the oil did you fill it properly with new oil??? If not going around a corner might oil starve the enging and thus the light would come on.
41magmag41 is offline   Reply With Quote
Old 02-25-2010, 08:56 AM   #15
maybe its time to top off your washer fluid, captain corners...
IM CONFUSED! JAPANESE IMPORT RECALL? HELP! mustangman General Yaris / Vitz Discussion 5 02-05-2010 08:00 PM
New owner that is confused! Yaris_Mirtle Fuel Economy Forum 18 04-21-2009 05:58 AM
TRD OR Eibach...i'm confused... hoahmaru Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 11-07-2008 08:25 PM
185/60/R15, confused Veliar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 04-23-2007 01:28 PM
Confused...vitz, yaris iLikeVitz General Yaris / Vitz Discussion 10 07-24-2006 03:24 PM
