Old 02-18-2010, 01:34 AM   #1
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Trunk space in a Sedan
What the biggest box that will fit in a 07 Yaris Sedan...I'm looking for something similiar to this design
http://caraudiofactory.com/dual-tran...ted-p-124.html
Old 02-18-2010, 11:52 AM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
do yourself a favor and stay away from Transmission line or horn loaded boxes. They require a lot of space, and there are easier ways to get loud. In fact, often times a simple, yet quality designed & built ported box will get louder.
Old 02-18-2010, 10:53 PM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I was going to say...let him do it. He'll get a hernia just trying to take it out one of these days. Poor guy.
Why would one need to get so intricate? I've installed single sealed 10"s with good power pushing them that would lift the back deck carpetting up off the frame there was so much pressure.
For example:
Clean, uncluttered, powered properly...what else can one ask for?
What are you powering said woofers with anyway?
― Thomas Paine
Old 02-19-2010, 10:51 AM   #4
_S7V7N_
_S7V7N_'s Avatar
Nice install on the amp and sub, i currently have two 12 inch Kicker cvr's but am flirting with the idea of selling them and getting some Alpine Type R's, I can push either set with the Hifonics Brutus 1600 watt, it'll do 550 rms @ 2 Ohms to each sub (1100 Watts Rms @ 2 ohms)
Old 02-19-2010, 11:19 AM   #5
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
A lot of deadening will be good for all that power!
CLA 250, 4MATIC
Old 02-19-2010, 11:34 AM   #6
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
Not sure you factored in the power loss via heat dissipation, 'tis a biotch. I'm considering upgrading my amp because of this, not to mention I have three type rs on one bxi1208d so they're pretty damn underpowered
PG TLD22 8V Line Driver
Old 02-19-2010, 12:07 PM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
power loss due to heat (at the amp) is mainly only a concern when you start dropping below the rating ohm load value... The best easiest way to combat that heat, is by upgrading your electrical... bigger alt (200+amps) and make sure it is designed to output a 15volt charge instead of 14-14.4. By having a higher voltage, and more current from the alt, you reduce the amount of amperage the amp will use... Remember Amps*volts=watts... so if you have 15volts, you'll need 7% less amperage... and amperage is what causes heat.
Old 02-19-2010, 11:13 PM   #8
_S7V7N_
_S7V7N_'s Avatar
Architect, are you running them in a sealed or ported enclosure ? And how many ohms are you running them at ? If i'm right the 12's are rated at 550 rms and come in either Dual 4 or 2 ohm voice coils
Old 02-19-2010, 11:27 PM   #9
The Architect
Give Me Resonance
theyre in their own vented enclosures and are each Dual 2, the final load before imp rise is about 1.1ohm's says the multimeter.
Old 02-20-2010, 01:45 PM   #10
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
yeah... that's the key... what is the load after impedance rise?
Old 02-20-2010, 02:19 PM   #11
The Architect
Give Me Resonance
I don't remember, I haven't measured it after rise in a long time. Ill try and check today after my ride home
Old 02-20-2010, 03:57 PM   #12
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
this is my set up in my sedan...hardly any space..but who needs a trunk?!
msfire671 is offline   Reply With Quote
Old 02-20-2010, 11:05 PM   #13
_S7V7N_
_S7V7N_'s Avatar
Nice set-up msfire, I just keep a cardboard box in my trunk when i haul groceries i just place it in front of my subs, If not we just take the Camry = ))
Old 02-22-2010, 12:35 PM   #14
_S7V7N_
_S7V7N_'s Avatar
Architect do you still have that set-up ?
Old 02-22-2010, 02:27 PM   #15
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'm a fan of passive radiators...saves a bit of space over the vented enclosures and looks like you have double the woofers...
Call me old school
― Thomas Paine
Old 04-16-2010, 09:22 PM   #16
Malifabian
Malifabian's Avatar
Drives: Yaris Sedan 2008
_S7V7N_That picture with the three subs, was each sub powered by a seperate amp? Just wondering because I'm new at all this car audio stuff. Its something similar that I wanted to put in my car. Idk if its even your setup since you kinda quoted Architect.
Malifabian is offline   Reply With Quote
Old 04-16-2010, 10:18 PM   #17
_S7V7N_
_S7V7N_'s Avatar
That is not my install, but he has a brutus 1200 for all three...My install is here
http://www.yarisworld.com/forums/showthread.php?t=26407
I need to update my pics cause i just installed a Hifonics Brutus 1200 on Easter.
Old 04-17-2010, 04:00 AM   #18
typicaljawaiian808
Drives: '09 Yaris Sedan
Big Box
The biggest box I fit was 30w x 16h x 27d.
Pioneer
Ascendant Audio
Sundown Audio
DC Power Engineering
Knukoncepts
Fosgate
Stinger
typicaljawaiian808 is offline   Reply With Quote
Sedan Trunk Lift eggyolk808 DIY / Maintenance / Service 9 09-11-2013 06:19 PM
Sedan - Painted chrome on trunk and smoked the tails (pics). Herbicidal Cosmetic Modifications (Exterior/Interior) 38 11-08-2009 06:55 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
