Old 02-18-2010, 07:14 PM   #1
YAR1S
YAR1S's Avatar
Whaaaaat is this noise?
Soooo I thought I heard a rattle in my engine and I lifted the hood and got a friend to rev my engine a little to figure out what was rattling, and to my surprise I heard a lot of air sucking noises....almost like someone had installed a turbo overnight It sounds like a pop off valve when revving from idle , but doesn't make a noise while revving from a rev.....
I had a good look at the hoses visible and felt around and nothing could be felt or seen...... It sounds like its either coming from inside the engine or the part where the air filter box meets the engine.
so, please....
someone explain what this noise could be?
Do I need a new air filter? (havnt changed in 6 months or so..)
Is a vacuum hose loose?
watttttttt?
http://www.youtube.com/watch?v=GLmNPUozXbo
-Jen <3
Old 02-18-2010, 11:27 PM   #2
I think all cars make that sucking sound, don't they?
Old 02-18-2010, 11:35 PM   #3
ztlonewolf
ztlonewolf's Avatar
Drives: 2008 red 3 dr S coupe
mine makes that noise too,always has
ztlonewolf is offline   Reply With Quote
Old 02-18-2010, 11:52 PM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yup, totally normal AFAICT.
You should get that filter cleaned regardless. A lot of dirt can accumulate in 6 months.
Old 02-19-2010, 12:16 AM   #5
YAR1S
YAR1S's Avatar
problem is.... its never done that before that loud........
well I guess I'll go get it checked out tomorrow and see if everything is normal....
-Jen <3
Old 02-19-2010, 12:58 AM   #6
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
It sounds rough. It could be a lot of things. Check the PCV valve and hoses. Run a good fuel system cleaner.
Worst case, it could be a burnt valve.
Old 02-19-2010, 05:43 AM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
That car sounds sick in the video,sounds like a diesel, i'd get it checked out by a mechanic before putting too many more miles on it,could be something minor or could be more serious and it doesnt sound normal to me..
Old 02-19-2010, 10:14 AM   #8
YAR1S
YAR1S's Avatar
Thanks everyone!
Heading to the mechanic today :)
-Jen <3
Old 02-19-2010, 10:27 AM   #9
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
my car makes that noise with my cold air intake, i have to change my filter its been almost 50,000 miles already lol
Aothachos is offline   Reply With Quote
Old 02-19-2010, 04:23 PM   #10
jambo101
jambo101's Avatar
Thanks everyone!
Let us know if it was a normal noise or what was the problem,if there is no problem i might have an issue with my car running too quiet
Old 02-19-2010, 04:41 PM   #11
YAR1S
YAR1S's Avatar
I took it to my mechanic and he said all was fine... it was normal sounding.... just with a sudden rev you can hear the suction more than you can with a normal rev.
:) so.... NEVERMIND!
:D
-Jen <3
Old 02-19-2010, 05:00 PM   #12
tomato
tomato's Avatar
hey, thanks for posting, Yar!s. I know I would have freaked too if I'd heard that noise.
Posting a vid on youtube was a great idea.
Old 02-19-2010, 05:08 PM   #13
YAR1S
YAR1S's Avatar
Thanks .... Im convinced its a new noise... oh well next oil change im getting a new air filter.
-Jen <3
Old 02-19-2010, 05:43 PM   #14
:D
How about a second opinion? If you say that it's louder than usual, then it might be something.
Old 02-19-2010, 06:02 PM   #15
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I have a CAI on my Jeep that makes loud sucking and whistling sounds when I gas it. I actually like it - makes it sound like a turbo or SC. It's the air rushing past the butterfly valve in the throttle body. The smaller the gap between the valve and the wall of the TB the louder the sound is, so it's only really loud when revving up from a low idle or gassing it to get some quick speed.
I don't think it's a problem for your Yaris, but check your air filter just to make sure it's not clogged and choking the engine a bit. It may also be that some gunk has accumulated around the valve in the TB "roughing up" the air as it moves past so a quick look in the TB to see if it needs cleaning would be something to check as well.
Old 02-19-2010, 08:40 PM   #16
YAR1S
YAR1S's Avatar
Thanks guys, I'll check it out when I change the air filter.
Is it pretty easy to look inside the Throttle Body??
-Jen <3
Very loud noise from the engine Stiv DIY / Maintenance / Service 27 10-27-2009 10:09 AM
strange noise before the car stops dani1983 DIY / Maintenance / Service 14 08-15-2009 11:56 AM
Beeping noise when opening door? minervamoon General Yaris / Vitz Discussion 14 07-25-2009 07:43 AM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
