#1 |
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3 Join Date: Oct 2006
bought some redline mt-90 to put in my yaris' tranny
i'll change it by tomorrow and will post results. i've ran this stuff in my corolla and it helps out a lot when the weather is cold.
So, how many quarts did you use?
I've used Redline in other cars/trucks. Good stuff. |
#3 |
ex-yaris owner
i drained the crap that was in there after i got it real hot. i actually let it drain for almost 45 minutes because i had to go to walmart with a friend during that time. when i got back i filled the tranny up with the redline and used two 1-quart bottles. i spilt a small amount while pouring and then after i was done i pulled the tube out of the filler hole and a small amount started dribbling out of the filler hole. that didn't seem right so i screwed the filler plug back in to stop it from leaking. i don't remember this happening with my corolla and it also uses 2 quarts.
regardless, i've put close to 70 miles on the car so far with the redline mt-90 and it feels pretty much the same with the exception of my tranny will last MUCH longer than running that stock crap. i guess having a brand new tranny won't show much of a difference when switched to synthetic unless its cold outside. |
#4 |
![]() ![]() ![]() ![]() Drives: 2007 Black Yaris sedan Join Date: Sep 2006
I might do the same thing,I might get mine flushed first.
| Test drove Fit, Versa and Yaris... Bought a Yaris! | AlexK | General Yaris / Vitz Discussion | 49 | 09-10-2007 05:35 PM |
| Just bought my yaris! | cblu07 | New YARIS Purchase Forum | 8 | 09-12-2006 04:36 PM |
