Old 02-18-2010, 09:00 PM   #1
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
Squeek!
So I my sedan is about 2 months short of turning 2 years, I have not changed my brakes at all. Everytime I step my brake I hear like a *squeek*, not one of those long ones just when I step and release...I dont know if that makes sense but anyone have any ideas as to what it is? new brakes? change brakes or clean and condition? please help!
thanks in advance!
msfire671 is offline   Reply With Quote
Old 02-18-2010, 09:03 PM   #2
YAR1S
YAR1S's Avatar
The brakes have things in them to make a noise when they get worn down... I'd get them checked and get some new ones.
-Jen <3
Old 02-18-2010, 10:32 PM   #3
Vang
Drives: 2008 Yaris Sedan
yep i get the same problem but it rarely happens.. usually when i either make a stop and no depress the pedal all the way or just do it too hard and sudden or its dirty since i live on a dirt road.. mines got plenty of life tho and just hit 10k miles this week
Vang is offline   Reply With Quote
Old 02-19-2010, 01:02 AM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
It could be the wear indicator. You need to get them checked. If the brakes get too worn, they'll damage the rotor and cost you more money.
Old 02-19-2010, 08:22 AM   #5
msfire671
msfire671's Avatar
awesome! thanks for the response yw friends!
Old 02-19-2010, 05:30 PM   #6
bankrobber
Drives: 2007 Yaris Hatchback
I have the same squeak sound. I believe somewhere on here I read that you can put some grease on it and it stoped. I have 82,000 miles and my front brakes are over 50% still. I didn't check the rear cause they should last longer than the front. And I never replaced drum brakes. The sound seems to come from the back though
Old 02-19-2010, 06:03 PM   #7
tomato
tomato's Avatar
yeah, but you never know.
OP, I'd get that checked. Always err on the side of caution
Last time I had a "squeaky shoe" noise, it was my CV boot going out. Not cool and not cheap.
Old 02-19-2010, 06:10 PM   #8
bankrobber
I dont think wear indicator because it only squeaks when pressing the brake pedal. I can be parked and it does it. Almost like a spring or something in the drum brakes needs to be lubed
Old 02-19-2010, 06:52 PM   #9
markitect
Can you hear it from outside the vehicle or just from the inside?
I've had a squeak when not even moving and it was the pivot on the pedal, little bit of grease took care of it.
markitect is offline   Reply With Quote
Old 02-26-2010, 08:25 AM   #10
msfire671
msfire671's Avatar
its just a quick sqeek that i hear once i stop to go over a bump or stop period...regardless, i will still get it check out just in case..i have about 26k on my yarii..lol..its about that time. thanks again!
squeek ob1bogie DIY / Maintenance / Service 4 11-05-2009 11:16 PM
squeek squeek firefly1_0 General Yaris / Vitz Discussion 2 04-16-2007 02:02 PM
