Old 02-19-2010, 02:14 PM   #1
colinr5779
Colin Richardson
Drives: Yaris Sr 1.8 Dual VVT-i
paintworkkkk
Alrite guys, I popd off my toyota emblem at the front of my car to put on the netz emblem! but i used a flat screwdriver and left a small mark :( any ideas what i cood do to sort this out ?, cheers colin
colinr5779 is offline   Reply With Quote
Old 02-19-2010, 02:25 PM   #2
Wita09
Drives: 09 Yaris Hatchback
pics?
Wita09 is offline   Reply With Quote
Old 02-19-2010, 02:28 PM   #3
yeah kinda hard to say or give advice without seeing what you want to fix.
Old 02-19-2010, 04:35 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
Use a bottle of touch up paint to fix the scratch or chip. Dont use the brush it comes with it will make a ugly glob mess that will probally look worse than if you didnt even fix it.
Just take a small toothpick and slowly fill in the area. May take several trys allowing it to dry each time till its slightly raised above the surface area of the paint surrounding it. Then very lightly take some fine sandpaper the kind used for sanding clear coat to sand it down to a flat level. Then some polish and wax and will look good as new.
