#1 |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
Need Some Wiring Assistance...
Alright so I recently installed Side Markers on my sedan and have them wired so they blink with the turn signals. I was thinking about it today and thought it would be pretty sweet if I had them on when the parking lights are turned on, but still blink with the turn signals. Would it be as simple as running another wire out of the marker harness to the parking light wire behind the headlights? If that's the case, could someone tell me exactly which wire it is?
UPDATE: The markers signal correctly when the parking lights are off, but when they're on the markers stay lit up: no signaling. Last edited by Focus_Sh1ft; 03-04-2010 at 01:02 AM. |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
jsut a heads up, make sure its not illegal in your area to have all the time side illuminated lights. i had a friend who got busted for having them on his car but his were 2 coloured (red on the back, orange on the front) i dont know what the exact details on his ticket were...just a heads up
#3 |
That's pretty lame...
Btw, a little more info on my setup: I have two wires running from each marker. One wire taps into the turn signal wire behind each headlight and the other is a grounding wire. |
#4 |
you'd need two SPDT relays to pull this off, not a big deal.
change the "power" wire hookup from the signal light to parking lights 2. use the signal light to power the relay 3. with the common wire on the relay hooked up to the parking light circuit, and pin 87A hooked up to your sidemarker, the sidemarker will now be ON whenever the parking lights are ON, and OFF whenever the signal bulb flashes. ![]() it'll need that center connector to work. pin 85 to ground pin 86 to signal light circuit (on each side) pin 30 to parking light circuit pin 87a to your sidemarker + wire pin 87 not used, tape it off
Been a long time messing with cars.. Last edited by Tamago; 02-24-2010 at 04:18 PM. |
#5 |
An even easier way would be to use two diodes. The diodes let the two functions feed the single indicator without feeding each other:
Side Lights.jpg |
#6 |
The diode idea sounds perfect. I'm assuming I can pick some up at a place like radioshack? The only thing I'm unclear about as to which wire controls the parking lights.
#7 |
1N4003 Diodes from RadioShack would be fine:
http://www.radioshack.com/product/in...ductId=2036269 ![]() The end with the white stripe goes towards the LED indicators. You can tap the parking lights at Connector B13 in the under hood fuse panel (the left connector pictured below). Any of the 4 green wires in the first row will work. Conn B13.jpg |
#8 |
CTScott, thanks so much for your help so far. Do you know which wire controls the parking lights behind the headlight (on the 4 pin plastic connector)? That would save me the effort of having to run a wire across the engine bay to the fuse box. Obviously if I have to it's no worries though.
#9 | |
#10 |
Alright so I used diodes, but no dice. The markers signal correctly when the parking lights are off, but when they're on the markers stay lit up: no signaling. I tried both of the two lower green wires but no difference. I'm not sure what to do now... the diode idea seemed flawless
![]() Out of curiosity, what purpose does that black and white wire serve? |
#11 | |
What I would do is to add a resistor in line with the parking light wire. This will make the LEDs glow, but less brightly from the parking lights. Then, when the signals flash, the LEDs will pulse from dim to bright. For the resistor I would experiment with 1K, 5K and 10K to see which looks best. The white/black wire is ground. |
#12 | |
#13 |
The parking lights and turn signals are separate bulbs. What you are doing is very similar to what is required for trailer lights, where the tail and turn signals feed a single bulb.
#14 |
Hah, you're right. I can't believe I never noticed the parking light just simply brightens for turn signals when it's on. I'm gonna go pick up some resistors
| Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | 06-10-2024 10:06 AM |
| Connecting wiring to small trailer | charles nelson | DIY / Maintenance / Service | 8 | 04-24-2012 05:39 PM |
| Wiring Pictures | MitchEvious | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 12-28-2009 11:43 AM |
| Wiring color code for 2008 LB? | charles nelson | DIY / Maintenance / Service | 0 | 04-25-2009 03:56 PM |
| Pioneer AVH-P4000DVD Wiring Adapter?? | maxiMOOM | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 02-11-2009 01:11 PM |
