Old 02-21-2010, 08:13 PM   #1
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Going active
Anyone here ran an active system in our car......I fell into a set of 5 1/4" ARC components and I already have a set of 6.5" components and a 4 channel amp....
was gonna run the 6.5s in the front and mount the tweeters to image where they should,but I can either run the 5.25s in the rear space or build pods in the kicks.......
has anyone tried it in our cars........what works.....I hate to use them for rear imaging as I will not benifit really as i have no rear passengers and would rather do kick pods....
My sub to use is still undecided.......I have a nice ID 10" that will work but also access to 2 12" ID subs for cheap and can build my own box and still deciding what subs to do before buying amp.....
I already have a Elemental Designs NINe.4 to run my comps and will either do depending on sub decision the NINe.2 to push 400w or the NINe.1 to push 1200w.....just depends on what I think will work,I like SQ,but also like it loud......so am leaning to the 2 12s and 1200w split between them....it wil make my hear blow when it hits but is painfull.......lol
Any ideas are welcome I know we got some guys on here that could help on this so I am open to whatever.....
Also the car will be in shows,but not sound compititions....but I like to build nice systems,money is not too much a concern but at the same time I got like 4 friends changing systems so I got access to products they used for les than 6 months and never abused and was tuned properly so it is like new......
I do all my own work and want to be in the 130db range with it or higher which I know the single 10 will not get me to.....unless the small car size makes it which I doubt...
MY tC hit 134DB in a compitition and came in second in my class due mainly to imaging issues and some tuning issues......
Old 02-22-2010, 07:22 AM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'm running fully active.
Three way Hybrid Audio 841 Pro SE set
Two IDQ 12"
Two ID Q 450.4 for the components and one ID Q 1200.1 for the two woofers
The source is a Pioneer Carrozzeria DEH-P01
I have plenty of processing power in the source. All the EQ'ing up to 36 dB slopes, a 4 way active crossover, 4 24 bit D/A converters (one for each crossover slope), Time alignment, and auto EQ...
What exactly do YOU want to do?
...Also, I'm in Vancouver, WA...
I'll be going up to BC for IASCA shows during the summer. I'll be going with Team Hybrids members. One of the is actually in the Seattle area. His name is Bill Pleasant. If you want to talk to someone that is close and knows something, he's your man.
― Thomas Paine
Old 02-22-2010, 12:04 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I plan on going err..... half active.... active between my midbass & mid.... but passive between the mid & tweet. No subs in the install... all three drivers located in, or near the door.
if you already had a set of 6.5's, I don't understand why you got the 5.25's.... if the 6.5 drivers were midbass heavy... that'd be one thing, you could make a 3-way.... but really... even then, a 5.25 would be bigger than you'd want... a 3-4" speaker would be a much easier install.
You see what SQ is running.... here's mine for comparison
Adire Koda 8" midbass
CSS WR125 4.5" mid
Cheap Audax tweet
160rms to the 8's
80rms shared to the mid & tweet.
Old 02-22-2010, 12:26 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Taln,
Are you doing the "quasi-active" thing? mid and tweet on a single pair of channels? All you'd prolly need is a cap for a 6 dB slope...
Get those plus the midbass on a beefy four channel and it'd work well. The only thing would be testing where you wanted your crossover point to be at. That 450.4 is going to give the 8.5 midbass at least 200 Watts at 12 Volts if I call for it. I'm thinking a good bit more actually...
I'll never use that much power though. I can't see Joe Pass and Ella Fitzgerald EVER needing that much power. It's really all about the headroom for me. Lot's of good signal Voltage and a great install is what I'm about.
My crossover point is going to be closer to 10K on the pro SEs since those mids I'm using are capable of over 7 octaves of good usable range. That's where the magic happens...the mid range!
― Thomas Paine
Chain Reaction Game steved Off-topic / Other Cars / Everything else Discussions 5134 10-25-2010 09:20 PM
Currently Active Users RogueYaris Off-topic / Other Cars / Everything else Discussions 6 06-05-2007 04:02 PM
