Old 02-23-2010, 09:18 PM   #1
cdydjded
Drives: Yaris LB Turbo
TC injectors and boost
Based on the experience of LTNoogie, Garm & ChinoCharles Iv come to the conclusion that that TC injectors are too big & the factory ECU can not control them. They all suffered from the same simptom, CEL, Rich Condition & high RPM misfires. I also know from experience that ECU's of most car today can only handle 10-20% larger injectors. Considering that the stock injector is +/- 190cc & the TC injector is +/- 380cc the problem is obvious. I feel that right now the best injector to use for boosted aplications with a factory ECU is the 1ZZ injector since LTNoogie has had positive results since he installed them.
cdydjded is offline   Reply With Quote
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 04:44 AM
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? trini_per4mance Forced Induction Forum 19 05-06-2009 01:18 PM
tC injectors cured my lean condition LtNoogie Forced Induction Forum 31 05-04-2009 11:02 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
