Old 02-25-2010, 10:11 PM   #1
vhicke
Drives: yaris
adding 6x9 speakers
I am going to be adding 6x9 speakers to my 2008 yaris sedan and i was wondering if i could mount without any major work(i have read the diy manual but need bracket)....Really was wondering if i could mount without bracket...If anyone has a idea and if i need a bracket is there a bracket that anyone knows of as i cannot find one anywhere.Thanks
vhicke is offline   Reply With Quote
Old 02-26-2010, 06:02 AM   #2
Yaris - GP
Drives: 2007 Yaris Sedan
Have installed 6*9's so I would say, please use the brackets. I made my own, but some where my measurements went a little off, so each speaker is only attached by 2 and not 4 bolts. I'm still using the factory HU, so the bass response isn't good (amp install in the pipeline).
However the overall quality of sound has increased.
Back to the brackets, you will see that when you line up the aftermarket 6*9 against the factory speaker, the factory speaker larger, so I don't think that the 6*9 can be installed without the bracket. It might actually fall through the speaker hole.
Yaris - GP is offline   Reply With Quote
Old 02-26-2010, 12:58 PM   #3
vhicke
Drives: yaris
Ok so if i was to change anything on my system would the 6x9 be better or whould changing the 6.5 in the front make for better sound....I have a new after market deck in...
Old 02-26-2010, 01:12 PM   #4
vhicke
Drives: yaris
Here is a link of bose 6.5 for the front doors....Will these fit...a sedan door...8"
http://cgi.ebay.ca/1-PAIR-GENUINE-BO...item3efd338b84
Old 02-26-2010, 03:14 PM   #5
vhicke
Drives: yaris
Can i reuse the original bracket for the 6x9....Cutting out the middle of the speaker...
Old 02-26-2010, 04:04 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Id buy some speaker adaptors on ebay. Make sure to get mdf the cheap plastic ones flex and rattle.
Old 02-26-2010, 04:34 PM   #7
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
i didn't mount mine with brackets, idk my friend did it for me at best buy in the shop lol
Aothachos is offline   Reply With Quote
Old 02-26-2010, 05:15 PM   #8
vhicke
Drives: yaris
that is the problem i cannot find adaptors on ebay.....I was looking and there is nothing for 6x9.....
Old 02-26-2010, 10:29 PM   #9
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
This what you looking for ?
http://cgi.ebay.com/6x9-3-4-MDF-Spea...item2302385755
http://cgi.ebay.com/MDF-Speaker-ring...item518f9b4ae2
Here's the search see if it works for you http://shop.ebay.com/i.html?_kw=6.5&_kw=mdf
Old 02-26-2010, 11:20 PM   #10
YarisSedan
http://cgi.ebay.com/ebaymotors/6x9-S...fAudioQ5fVideo
This is what you need thats the one i have but they rattle a bit since they flex unlike wood.
Old 02-26-2010, 11:53 PM   #11
vhicke
Drives: yaris
Perfect thanks for the help guys.........So which one is better...the plastic looks like it is ready to use and the wood one is a little thick...
Old 02-27-2010, 12:24 PM   #12
vhicke
Drives: yaris
so went with the plastic one.....see if it works and let everyone know...Thanks for everyone's help...
Old 02-28-2010, 11:49 PM   #13
GeneralDon7
Drives: Yaris Sedan
I have Those exact brackets, yes they will rattle with significant bass, I fixed mine with a little insulation in betweenI had to sand mine a little to get my speaker to fit snuggly as well.
GeneralDon7 is offline   Reply With Quote
Old 03-01-2010, 05:10 AM   #14
CpKi1g3
High speeds are fun...
CpKi1g3's Avatar
Drives: 07' Polar White sedan Base
Send a message via MSN to CpKi1g3 Send a message via Yahoo to CpKi1g3
well its been covered but i highly recommend the brackets and some sound dampening material like Dynamat to name one. i have a set of pioneer's on the back of my sedan and rattle with bumpy roads and sub'n. i believe i did install the brackets for the front and don't rattle at all.
Ps. the front speaker is still going to sound at the same sound level due to the design of the car for the front speakers stock or aftermarket.
CpKi1g3 is offline   Reply With Quote
Old 03-01-2010, 12:23 PM   #15
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Huh?
how loud the speakers sound is a direct reflection of the wattage you put into the speaker, and how efficient that speaker is. Stock speakers are usually more efficient than aftermarket.
Also... distortion can give the illusion of a speaker being louder even when it is not. The volume has very little to do with the design of the car.... until you start talking about extreme levels at which you'd need thousands of watts of power and subs.
Old 03-02-2010, 03:33 AM   #16
CpKi1g3
CpKi1g3's Avatar
its nothing with the wattage its that the speakers are way down by the floor i used the same speaker on my previous car and they seamed louder on the other car and i am using the same setup with the same headunit. even my homie which installs sound systems tripped out about how the car was designed that even switching them front speakers didn't even make a real difference and he even told me that it was that they were way down there that are too far to hear. the tweeters are the ones that make the sound for the front more than the speakers them selfs on my car.
Old 03-03-2010, 12:08 PM   #17
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
ughh... i wish I didn't have to start working now... The car wasn't designed with any regard to the speakers/sound, trust me.
Old 03-03-2010, 04:28 PM   #18
YarisSedan
Arnt all speakers on all cars mounted on the doors low? Ive put in new speakers on my car and i can tell a difference.
Which Speakers??? Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 23 12-08-2009 07:52 PM
Factory deck, new speakers sound no sound?? alan1828 DIY / Maintenance / Service 4 10-25-2009 03:36 PM
Fitting rear speakers in Toyota Yaris nish1979 In Car Entertainment + Electronics (audio / video / alarm) 4 03-22-2009 11:56 PM
Speakers make noise when engine is on Lafiro In Car Entertainment + Electronics (audio / video / alarm) 13 01-07-2009 08:52 PM
how to install back speakers? ebowers83 In Car Entertainment + Electronics (audio / video / alarm) 4 09-10-2006 09:29 PM
