Old 03-03-2010, 08:47 PM   #1
ham
ham's Avatar
Drives: 2007 Yaris Hatch 5-Speed
Brakes?
I have a 2007 Lift Back Yaris. How do I remove my rear drum brakes?
ham is offline   Reply With Quote
Old 03-04-2010, 07:45 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Why? To paint 'em up? If you have under 50K miles they will be fine - maybe some dust in there.
Old 03-04-2010, 07:54 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
first find a jack
place jack under car at one of the rear jack points
find lug nut wrench
loosen 4 wheel nuts on said wheel, slightly
turn crank on jack clock wise untill tire is off of the ground
remove loosened wheel nuts (if you did not loosen them enough apply parking break)
remove wheel from car
if parking break was applied, release it
pull on drum with even pressure, it should slide off easily
if it does not slide off easily try tapping with a hammer between studs and try to slide off again
or read this thread
http://www.yarisworld.com/forums/showthread.php?t=12333
Old 03-05-2010, 03:11 PM   #4
ham
ham's Avatar
Thanks black yaris.
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 12:04 AM
A few questions about suspension, tires, and brakes. supmet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-02-2009 04:55 PM
Weird question about my brakes brainless twit General Yaris / Vitz Discussion 8 01-22-2009 10:59 AM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
