Old 03-04-2010, 01:56 PM   #1
ddongbap
SpeedVentures 03/05/10 Streets of Willow, Track Day
http://speedventures.com/events/eventdetail.aspx?id=271
Look at this poor guy with a 100hp Yaris.
http://speedventures.com/events/atte...id=-1999999543
Old 03-04-2010, 09:57 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Can you go and just watch?
Old 03-04-2010, 11:15 PM   #3
ddongbap
I think you can.
Old 03-07-2010, 12:36 PM   #4
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Yes you can go and just watch.
Was that you in the yaris? It looked pretty good out there, I saw him spin once.
I was in my RX7.
Old 03-07-2010, 08:35 PM   #5
ddongbap
YEA THAT WAS ME. DUDE U WERE THERE?!!?!?!
Old 03-07-2010, 08:35 PM   #6
ddongbap
Which one? FD or FC?
Old 03-07-2010, 08:36 PM   #7
ddongbap
I tried to slide the tail slightly, by turning hard. I was trying to get the car pointed RIGHT at the yellow entry burm thing. I was using my 350mm steering wheel, and I didn't flick it in counter fast enough. I was sorta used to the 300mm one I was using most of the day. So the rear end said, NOT ENOUGH, and I ate laterals.
I think I attempted that slide 10+ times, but I've only landed it twice.
Did you also happen to catch my crazy oversteer? I point passed my friend in his red S2k. Then I got fixated on his butt, so I took his line, and his speed on the skidpad corner. The rear end was having none of that.
Old 03-07-2010, 10:27 PM   #8
largeorangefont
Break'em off some.
Red FC
Old 03-07-2010, 10:29 PM   #9
ddongbap
Yep, I def saw you. I think.
Old 03-07-2010, 10:30 PM   #10
largeorangefont
Break'em off some.
Yea I heard it then looked up and saw you sliding. You need some rear tires with tread on them :)
Do you have that 23mm sway bar on your car? If so how do you like it?
Old 03-07-2010, 10:33 PM   #11
ddongbap
Yep =T
I'm running those Azenis as long I can.
And I like the sway. The rear lets you know its not lame. I'm going to try to put some toe in the rear using some shims for the next event.
Old 03-07-2010, 10:35 PM   #12
largeorangefont
Break'em off some.
Yep =T
Yes some camber and toe in the rear will help. Seeing yours out there made me want to bring mine out.
Old 03-07-2010, 10:42 PM   #13
ddongbap
It probably isn't anything close to a RX tho.
Old 03-08-2010, 04:25 AM   #14
ddongbap
So I didn't have timing, but based on my video, I pulled a 1:47 on the second heat of the day. The camera ran out of batteries right after.
Old 03-08-2010, 01:49 PM   #15
largeorangefont
Break'em off some.
I ran a 1:34.4
Old 03-08-2010, 02:16 PM   #16
ddongbap
Man, i'm slow.
Most of the track was pulling way faster times than me.
June 21st Cayuga TMP track lapping event, 2009-6th Touge.ca Touge.ca Canada 0 06-04-2009 06:47 AM
Black Friday Bob_VT Off-topic / Other Cars / Everything else Discussions 70 11-29-2008 07:07 AM
First track day, did not go so well. Need some suggestions Boy Blue Tracking, Racing, Auto-X Forum 25 10-23-2008 10:10 PM
Willow Springs Track Day This Sunday! 03Z33 California 4 09-23-2007 12:34 PM
Streets Of Willow track day - Non Yaris Warning. largeorangefont Photo-Video-Media Gallery 23 06-03-2007 08:03 PM
