Old 03-06-2010, 01:07 AM   #1
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
HIFONICS ZXi6.5C ZEUS 6.5" 500W Component Car Speaker
When connecting a four channel amp to these you can run One channel to the Tweets and One channel to the 6.5 ( one set per door ) (so Two channels to the left door two channels to the right ) Correct without overpowering them. With the channel to the 6.5's on Full and the Tweets on High pass Correct? i'm just going with the Crunch 900.4 Here's the specs
# PowerZone Series 4-Channel AB Car Amplifier
# RMS Power Rating:
* 4 ohms: 57.5 watts x 4 chan.
* 2 ohms: 112.5 watts x 4 chan.
* Bridged, 4 ohms: 225 watts x 2 chan.
# Dynamic (Peak) Power Rating:
* 4 ohms: 115 watts x 4 chan.
* 2 ohms: 225 watts x 4 chan.
* Bridged, 4 ohms: 450 watts x 2 chan
Component Specs
6-1/2" Component System
Low Profile OEM-Fit Design
Swiveling 12mm Neodymium Silk Dome Tweeters
Moisture-Resistant Butyl Rubber Surrounds
Ultra-Rigid Titanium Ceramic Composite Cones
Chrome Raised T-Yoke
High Mid Bass Impact
CHrome Anti-Resonant Stamped Steel Basket
18 dB per Octave High Definition Passive Crossover
Wide Nominal Power Range
Installation Hardware Included
100 watts RMS<-----Is this for each the 6.5 and Tweeter ?
500 watts Peak
Frequency Response: 60 - 30,000 Hz
Sensitivity: 91 dB
4 ohm Impedance
Top Mount Dept: 2.44"
Old 03-06-2010, 01:18 AM   #2
_S7V7N_
_S7V7N_'s Avatar
Or should i go with this one....It would almost hit the RMS and isn't much more than the Other.....900 is 74.95 The 1400 is 89 bucks..Free shipping on both.
# RMS Power Rating:
* 4 ohms: 87.5 watts x 4 chan.
* 2 ohms: 175 watts x 4 chan.
* Bridged, 4 ohms: 350 watts x 2 chan.
* 4 ohms: 175 watts x 4 chan.
* 2 ohms: 350 watts x 4 chan.
* Bridged, 4 ohms: 700 watts x 2 chan.
# MOSFET power supply
# LED power and protection indicators
# Tuned Bass EQ (0-12 dB bass boost at 45 Hz)
# Speaker-level inputs with soft turn-on
# DC, short, thermal, overload protection
# Illuminated CRUNCH logo
# Variable high-pass filter (60-1200 Hz, 24 dB/octave)
# Variable low-pass filter (30-250 Hz, 24 dB/octave)
# Variable input level control: 0.2V-5.0V
# Frequency response: 30-1,200 Hz
# Dimensions: 13.38"L x10"W x 2.16"H
# 4-gauge power and ground wiring is required for instal
Old 03-06-2010, 10:38 AM   #3
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
The rating is for the tweeter and mid. Get the second One if those are your choices
PG TLD22 8V Line Driver
Old 03-06-2010, 12:24 PM   #4
_S7V7N_
_S7V7N_'s Avatar
Do you need the spacer on the door or do they slide right in without hitting the window ?
Old 03-06-2010, 01:30 PM   #5
The Architect
Give Me Resonance
id recommend a .5" or .75" spacer
Old 03-11-2010, 07:33 PM   #6
_S7V7N_
_S7V7N_'s Avatar
Question for Architect
Wow !!! These things are hellacious looking. I see they have -3 +3 or 0 db on the crossover connections, what is the best to use.
Did you run the power so the sub would illuminate ? The hifonics logo .
Old 03-11-2010, 07:51 PM   #7
The Architect
Give Me Resonance
0db is fine.
Old 03-11-2010, 08:23 PM   #8
_S7V7N_
_S7V7N_'s Avatar
What about the illumination ?
Old 03-11-2010, 08:27 PM   #9
The Architect
Give Me Resonance
I wouldnt even bother unless you intend of cutting out the plastic mesh on the door panel to see it/make it worthwhile
Old 03-11-2010, 08:47 PM   #10
_S7V7N_
_S7V7N_'s Avatar
I can't wait to get them installed, my amp should be here by monday, these things look sexy as hell. Where did you mount the crossovers ?
Old 03-11-2010, 08:52 PM   #11
The Architect
Give Me Resonance
down to the right behind the door panel with some ribbon sealer to hold it to the door.
Old 03-11-2010, 10:57 PM   #12
_S7V7N_
_S7V7N_'s Avatar
I think i'm going to show mine off, and figure somewhere to put them on the door panel facing us.
Old 03-11-2010, 11:14 PM   #13
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
keep the crossover away from the center of the car(in the front).... transmissions have a funny habit of inducing noise via the inductors (coils) found in crossovers.
Old 03-12-2010, 10:50 AM   #14
_S7V7N_
_S7V7N_'s Avatar
They'll be mounted on the door, Do you happen to know if there's wiring in the door for the power windows and locks ? if so how many amps, i may just grab the power off one them to run the Logo Led's off the speakers.
Old 03-12-2010, 03:57 PM   #15
swidd
Drives: Yaris HB
would it be a bad idea to put the crossovers on top of the amp with some velcro to hold it in place?
Old 03-12-2010, 05:09 PM   #16
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
shouldn't be an issue.... crossovers generally aren't sensitive to heat... tho the amp may be prone to overheating if the heat sink is covered up.... tho I kind of doubt it.
Keep in mind however, for every 10degrees you drop the operating temperature of an electric circuit... you double its life expectancy.
Old 03-12-2010, 11:05 PM   #17
_S7V7N_
_S7V7N_'s Avatar
They provide just enough speaker wire to run the speakers directly to the crossover if you mount it on the door, then all i have to do is run one speaker wire to the trunk where my amps going to be. I think i'm going to show off them crossovers they look kinda nice.
Old 03-13-2010, 09:49 AM   #18
swidd
Drives: Yaris HB
Mount them visible on the inside of the door? With all the wires going into the door somewhere?
Photo-Scavenger Hunt - THE LIST Black Yaris Photo-Video-Media Gallery 22 03-04-2009 08:35 PM
YAR1S - Photo Scavenger Hunt! YAR1S Photo-Video-Media Gallery 4 03-02-2009 07:44 PM
Black Yaris - Photo-Scavenger Hunt Black Yaris Photo-Video-Media Gallery 2 03-01-2009 04:13 PM
Photo Scavenger Hunt Ideas Thread Black Yaris Photo-Video-Media Gallery 41 02-28-2009 08:54 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
