Old 03-12-2010, 01:32 AM   #1
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Is my auto tranny dying?
So when my car goes above 30mph it starts making a loud buzzing noise and the car starts to vibrate. my right side hub bearing was messed up so i am not sure if this noise/vibration is the cause of this because its starting to go out. my friend who's jettah's auto tranny gone out said the noise he is hearing was similiar to his before his died, except a million times louder. i have noticed that my car wont engine break as good in either 1, 2, or 3. any insight on this would be great, thx again yw peoples.
Also i only have 19k miles on it. Would my warranty still cover a tranny?
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 03-12-2010, 06:45 AM   #2
Maxh91
Maxh91's Avatar
Drives: Red 3 Dr HB 2008 Auto.
for the warranty, dont worry! Your transmission is cover.
In Canada the Tranny is 5 years/100 000Km.
Maxh91 is offline   Reply With Quote
Old 03-12-2010, 07:16 AM   #3
eii
Rides canyon walls
eii's Avatar
man i hope its not the problem, if it is i wish they could put in a manual instead..lol.
Old 03-12-2010, 08:23 AM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Doubt it would be a tranny so early in the cars life.I'd be more inclined to think it might be something to do with that messed up bearing maybe whatever caused that problem also buggered up something else like a CV joint, If you are traveling at highway speeds and you throw the car in neutral and coast at idle rpm's does this noise change in any way?
I wouldnt do anything other than diagnose the problem if its still under warranty.
Old 03-12-2010, 03:03 PM   #5
eii
Rides canyon walls
eii's Avatar
its still makes the noise when i put it into neutral while cruising.
