Old 03-13-2010, 12:26 PM   #1
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
Heater Feet
My heater and A/C work fine in every setting and I have no issues with the defroster. However, when I have the arrow pointed to blow air below, I hardly feel any air. It feels like air is leaking from the top. Anyone else have this problem?
KrazyDawg is offline   Reply With Quote
Old 03-13-2010, 12:59 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Take off your shoes and you'll feel the air flow below better.
There's always some air coming out of the upper vents when you have it turned to the bottom outlet.
Old 03-13-2010, 01:10 PM   #3
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
Here's a cool chart CTScott posted that shows how the system works in each position. Helpful to look at: http://www.yarisworld.com/forums/sho...1&postcount=11
BuildCode is offline   Reply With Quote
Old 03-13-2010, 01:14 PM   #4
MadMax
MadMax's Avatar
The heater in the Yaris is a bit underwhelming; but considering that I am comparing it to a 4.0 I6 Jeep Wrangler heater that is not surprising. The latter is cranking out the heat almost as soon as I get to the end of the driveway, with my Yaris it will be several minutes down the road before I can even feel a slight indication of warmth.
I am just glad I live someplace where I don't need it too often, and if I didn't I would most definitely have gotten the cold weather package!
Cheers! M2
Old 03-17-2010, 01:07 PM   #5
KrazyDawg
KrazyDawg's Avatar
The A/C works a lot better than my 95 Civic but in the Civic, the heater for blowing hot air towards your feet was significantly better. It worked right away and in the Yaris, I wouldn't feel it after the car was already warmed up.
Old 03-17-2010, 01:20 PM   #6
127.0.0.1
Cheers! M2
huh ? I have the cold weather pgk (with embiggened heater) and that thing will roast me in any weather.
Old 03-17-2010, 01:59 PM   #7
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
As a point of interest... I've noticed from watching my Scangauge II that at idle the engine can't maintain more than about 160F-170F coolant temperature with the standard (non-heavy-duty) heater on high, in 40F-50F weather.
And having the heater on as the car warms up *substantially* delays the warm up time. That heater core makes for quite a radiator.
sbergman27 is offline   Reply With Quote
Old 03-17-2010, 03:03 PM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I think it's normal.
Old 03-18-2010, 10:07 AM   #9
hey.. when the air is pointed down (to the feet) there's always some air that comes out from the windshield. I don't know if that's part of the cold weather package, but it did that on both my echo and my yaris.
it doesn't bother me though, cuz i know it will keep my windshield clear for a long time :)
Old 03-18-2010, 10:50 AM   #10
Yaris Hilton
Smile
That's normal in most cars.
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
Yikes, thats an expensive block heater HDS DIY / Maintenance / Service 2 12-17-2009 07:30 AM
My $7 Interior Upgrade - Center Heater Vents Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 54 05-18-2009 08:51 AM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
