Old 03-14-2010, 12:00 PM   #1
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Another R-comp thread
Has/does anyone auto-x with r-comps on their Yaris. I don't want to hear the story of the guy rolling his Yaris. I want to know from personal experience people that have.
I would like to know what type of tire you ran and your suspension set-up for it.
Old 03-14-2010, 07:31 PM   #2
ctrj
Drives: 07 Yaris Sdn, 97 4Runner
I know Garm has a set, but hasn't run them yet. I'm thinking about doing it next season. Not sure yet though.
RJ
2007 Toyota Yaris Base Sedan -5 speed
SOLD
ctrj is offline   Reply With Quote
Old 03-17-2010, 07:12 PM   #3
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Here are some vids of me in my Yari . The white Yaris (07) has TRD shocks with Tein springs . The blue Yaris (09) has TRD shocks/springs/sway . Both Yari utilize the same wheel/tire combo , which is 16x6.5 +40 SSR Type C wheels in conjunction with 205/45/16 Hoosier A6 tires .
http://s208.photobucket.com/albums/b...MyMovie1-1.flv
http://s208.photobucket.com/albums/b...nt=YarisIX.flv
Old 03-17-2010, 07:50 PM   #4
advocate
Drives: car
Someone rolled their Yaris while on r comps?
Old 03-19-2010, 08:56 PM   #5
seth_man
seth_man's Avatar
Drives: 08 Liftback
i ran hankook z211 C30 compund 205-50-15 last year. they did very good imo. so much grip, the wheels wouldnt lock up no matter how hard i stood on the brakes (240lb dude). never every felt like it was gonna roll over.
suspension setup started off as out of the box megan coilovers, but now...
Front
Megan Shock Tubes
WRX Koni inserts
450lb Eibach 2.5id Spring
Poly Bushing under the top mount plate
Ford Focus Endlinks
Rear
Ford Focus Koni shocks
Megan Spring Bases
Eibach 500lb 2.5id spring
TRD swaybar
seth_man is offline   Reply With Quote
Old 03-25-2010, 12:23 AM   #6
lilredrocket
Slowy getting there
Drives: 08 Liftback
Where did you get the megan shock tubes and any problem fitting the shock you used.
Old 03-25-2010, 04:34 AM   #7
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Damn, SethMan has a crazy a$$ setup!!!
Old 03-25-2010, 08:45 AM   #8
seth_man
seth_man's Avatar
Drives: 08 Liftback
i purchased the megan coilovers used from a guy on this forum. they were good while the lasted but then started leaking and the endlinks that came with the kit were a joke.
the top of the front shock unscrews from the threaded shock tube. pull the guts out and put whatever you want inside. just so happens they fit koni inserts from my wrx quite well. the rear focus shocks bolt right up.
The eibach race springs are the same 2.5" inside diameter as the megan springs, i got them at a swap meet for $1 per spring, the top poly bushing is a left over from a rear differential outrigger bushing kit for my wrx, tool all the slop out of the front mount, that 1/4" that it could move up and down is gone.
i dont think its that crazy, ive seen way more crazy stuff out there, my car is still comfortable to drive everyday.
Old 03-25-2010, 02:38 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
thanks for sharing sethman.
Old 03-25-2010, 03:25 PM   #10
lilredrocket
Slowy getting there
Drives: 08 Liftback
Thank you for the info! I can see it helping people try new things...
Old 03-25-2010, 05:01 PM   #11
Morgan
Morgan's Avatar
Drives: 07 MM LB
I raced three events on my rcomps and never rolled? I think you'll be okay ;)
Old 03-25-2010, 05:17 PM   #12
Jason@SportsCar
Under the right conditions most any car can get on two wheels. Your driver inputs will have the biggest effect on this. Don't get in over your head and you wont have a problem.
Avoid getting the car sideways, and avoid the late brake turn-in off throttle combo, If you are on the gas it is much harder for the car to get up.
I saw this happen first hand, it was awesome.
Old 03-25-2010, 10:00 PM   #13
lilredrocket
Slowy getting there
Drives: 08 Liftback
Would doing the shock setup that Seth_man did be legal in HS?
Old 03-25-2010, 11:29 PM   #14
seth_man
seth_man's Avatar
Drives: 08 Liftback
i just read the 2010 rulebook and it looks like my suspension is HS legal
Old 03-26-2010, 03:29 AM   #15
justjesus
justjesus's Avatar
Not quite. MUST use stock springs in HS.
Old 03-26-2010, 09:11 AM   #16
lilredrocket
Slowy getting there
Drives: 08 Liftback
If using the shock tubes and shocks for different makesis ok I guess the Yaris does have konis available for it.... hmmmm
Old 03-26-2010, 10:24 AM   #17
Jason@SportsCar
Shocks can vary +/- 1" in overall length, but must use the OE mounts, and can have a maximum of two adjustments (compression/rebound). I have no idea what his setup would look like based on his post.
His spring change would not be legal.
Old 03-26-2010, 01:23 PM   #18
lilredrocket
Slowy getting there
Drives: 08 Liftback
I know the springs would not be legal but I guess the front struts wouldn't be legal because shock tubes are not on the Yaris from the factory...
The open political discussion thread. Read the first post! eTiMaGo Off-topic / Other Cars / Everything else Discussions 342 09-15-2009 12:34 AM
Yaris of the Month Feedback Thread! jekqmb General Yaris / Vitz Discussion 1 09-01-2009 12:34 AM
Post Whores-aka Yaris chat thread Black Yaris Off-topic / Other Cars / Everything else Discussions 21 07-12-2007 05:37 PM
