Old 03-16-2010, 10:36 PM   #1
Corykins
Drives: 2008 Yaris
A/C Vent Noise
When my A/C is on, it sounds like something is fluttering in the duct. It doesn't appear to be blocked or anything, but the sound is pretty consistent.
Common issue?
Corykins is offline   Reply With Quote
Old 03-16-2010, 10:56 PM   #2
Drop your passenger side glove box and see if something got sucked into the blower (which is right behind the glove box).
Old 03-16-2010, 11:40 PM   #3
Corykins
Drives: 2008 Yaris
Thanks for the tip. I went ahead and pulled the glove box out, unfortunately I can't seem to find anything that might be causing the problem. It sounds like it's coming from the central vent, luckily I'm still under warranty. Looks like I'll be taking a trip to the dealership, unless you have any other suggestions?
Old 03-17-2010, 08:47 AM   #4
Shine a flashlight into the central vents and see if you can see anything rattling there. The duct goes in about a foot before making a sharp downward turn. Access beyond that requires removing the top of the dashboard.
Old 03-17-2010, 10:15 AM   #5
sex
sex's Avatar
Drives: 09 5DR
Is it only when you press the A/C button or when you turn the fan speed up for any blower position? Does it happen in recirculate or open or both? How about parked vs local vs hwy?
Old 03-17-2010, 10:54 AM   #6
Corykins
Drives: 2008 Yaris
It seems to be apparent only on speeds 3 and 4 which leads me to believe it is in fact something stuck in there. Airflow setting and where I'm driving don't seem to have much of an effect.
Old 03-17-2010, 12:28 PM   #7
swidd
Drives: Yaris HB
You can quite easily (as in, without cutting your fingers) unscrew the bottom of the blower motor housing, and take a look the fan. I put some WD-40 in there, and it made no difference whatsoever to the sound from the motor itself.
Old 03-17-2010, 02:38 PM   #8
eht13
Drives: .
FWIW, mine made a similar sound for a couple of days... and then just when I was starting to get annoyed and about to take it in, it went away by itself. That was a few months ago. I've had similar situations in other cars too, where it seems like the cause of the sound gets "worked through" and then is gone.
eht13 is offline   Reply With Quote
Old 03-17-2010, 11:37 PM   #9
OtownYaris
OtownYaris's Avatar
Drives: Meteorite Yaris Liftback
Send a message via AIM to OtownYaris Send a message via Yahoo to OtownYaris
I had the same issue until about a minute ago. I just pulled down the glove box and found a pine needle in my blower fan. Problem solved.
OtownYaris is offline   Reply With Quote
Old 03-18-2010, 08:30 PM   #10
Corykins
Drives: 2008 Yaris
Found it! A thin piece of plastic from a cigarette pack wrapper was the culprit! I'm SO glad I don't have to go to the dealership. I probably would have been made fun of mercilessly, not only by the mechanics but by my boyfriend as well. Thanks to everyone for their help!
Old 03-18-2010, 10:49 PM   #11
QR25DE_SpecV
QR25DE_SpecV's Avatar
Drives: 2006 Sentra SpecV
Another reason to quit smoking, my love
It's not what you drive, but what drives you
QR25DE_SpecV is offline   Reply With Quote
Old 03-22-2010, 02:08 PM   #12
the air does get sucked from the air by the feet of the passenger side... that's probably why it was able to get stuck on the fan there.. hehe
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
A/C Vent Trim Rings TinyGiant Cosmetic Modifications (Exterior/Interior) 25 06-19-2010 04:09 PM
A/c blower motor noise!!!! LBdriver General Yaris / Vitz Discussion 28 09-12-2007 07:46 AM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 03:27 AM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
