Old 03-18-2010, 01:54 PM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Brake light on dash board won't turn off.
Hey people,
I noticed yesterday that my brake light would flicker on and off when I was driving. I drove it today, and it would not turn off. Has anyone else experienced this same problem?
marlondog is offline   Reply With Quote
Old 03-18-2010, 02:36 PM   #2
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Did you check you brake fluid level?
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 03-18-2010, 04:15 PM   #3
marlondog
marlondog's Avatar
No, but I will. I will also check the breaks as well. I had break work done several months ago, so I may have to take a second trip. Any other reasons that this light should come on?
Old 03-18-2010, 04:30 PM   #4
fmicle
fmicle's Avatar
It comes on when you pull the e-brake as well... But I doubt you are driving around with the e-brake on You may want to check the e-brake sensor (switch thingy), it should be under the handle somewhere, make sure it's unobstructed and clean...
Old 03-18-2010, 08:36 PM   #5
marlondog
marlondog's Avatar
Found out what the problem was. The brake fluid cap was loose, and some fluid leaked out. I just added a little, and light turned off. Thanks once again.
Old 03-18-2010, 09:34 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
how often do you open the hood? next time you're under there, maybe check the engine oil level too, (i hear that should be changed every once in awhile)
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
F/S Dash Light Dimmer Switch 1NZYaris1 Items for Sale by private party 4 09-26-2012 03:55 AM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
