Old 03-18-2010, 05:09 PM   #1
Hershey
Exclamation Noticed possible oil leak ...
on the '08 automatic sedan while doing an oil change . Found oil on the passenger side of the block that seems to be coming from above of it and flowing down to the oil pan seal . Cleaned off the pan and block . Will take it for a spin and put it back on ramps to see if it reappears . I haven't spilled any oil while pouring it or no one else has done so . Has anyone had this issue ? Will post if find more oil leaking . THANKS
Old 03-18-2010, 11:59 PM   #2
Hershey
took it for 80 mile trip and rechecked to find nothing . Will take a look every now and then . Keep my fingers crossed .
Old 03-19-2010, 08:20 AM   #3
bronsin
bronsin's Avatar
Probably just a spill (however unintentional)when you added oil...
Old 03-19-2010, 10:46 AM   #4
MadMax
MadMax's Avatar
Most likely it is as bronsin said, it's happened to me before; but if it happens again it's still under warranty, right? If so, take it to the dealer...
Cheers! M2
Old 03-19-2010, 11:28 AM   #5
Hershey
yup , only has 18,000 miles . Plenty of warranty left . Will take a look at it every 1,000 miles or so .
Old 04-19-2010, 08:40 PM   #6
Hershey
Exclamation oil still leaking
checked for oil leak again and found it's still doing so . We found another '08 YARIS sedan owner who had the same issue , www.carsurvey.org/reviews/toyota/yaris/r125809/ , hopefully ours is the same leak and not something different . Our '08 sedan was manufactured in APRIL of 2008 . This was during the high demand for the YARIS when gas prices were near $5 a gallon . Makes me think the YARISes produced during that time frame where slapped together to keep up with demand leading to errors . I suggest anyome who purchased an '08 at that time to take a look for any leaking oil . If not able to do it yourself then have TOYOTA service center or a trust worthly mechanic look for this . Will keep you informed after we take it to the dealer .
Old 04-19-2010, 08:56 PM   #7
Hershey
found this as well , www.carpros.com/topics/oilleak.htm , valve cover gasket may be the culprit with only 13,000 miles for an '06 ( maybe meant '07 ) . Ours has about 18,000 miles and use 5w-30 synthetic . HAVE NOT SPILLED MOTOR OIL OR OVERFILLED ENGINE ( about 3 and 3/4 quarts to fill ) .
Old 04-19-2010, 09:30 PM   #8
Hershey
found this thread as well from 6/18 of '07 . www.yarisworld.com/forums/showthread.php?t=6562 .
Old 04-19-2010, 11:12 PM   #9
Hershey
found some timing chain cover leaks for 1.3 Ltr. YARISes in EUROPE as well . http://www.kelsey-forums.co.uk/cgi-b...num=1207949887 .
Old 04-19-2010, 11:30 PM   #10
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Clean the engine and tighten the timing chain cover and the valve cover. Then watch for leaks. A clean engine will tell you where the oil is coming from.
Old 04-19-2010, 11:44 PM   #11
Hershey
cleaned the engine . I'll let TOYO techs do the tightening with a torque wrench if needed under the 3 yr./36 month warranty . They may need to put dye in engine to locate the leak . Just giving YARIS owners a heads up on this issue .
Old 04-20-2010, 06:43 AM   #12
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
I HATE LEAKS!
Hope its nothing major and just some stupid gasket or a loose nut.
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 04-20-2010, 08:00 AM   #13
Mines been leaking for a while too, but I just live with it. It's not enough of a leak that there's oil dripping, just enough to make the back of the block wet and bottom of the timing cover wet.
Old 04-20-2010, 11:42 PM   #14
yarrr
Drives: 07 sedan
Ya those robots get careless when they are in a hurry...
Old 04-21-2010, 12:44 AM   #15
Hershey
not everything is robotic .
Old 05-29-2010, 02:11 AM   #16
Hershey
well the leak is back . Took a few pics of where the oil was building up on back of engine and took it to dealer to show the photos . Couldn't get us in , but did put some dye in engine and drive until appointment for next Saturday . Hopefully by then the dye in the oil will be able to pinpoint it . Quite sure it's the timing chain cover . Will try to post the pics of oil leak . We're not that computer savvy . I suggest others to look out for this issue . Especially '08s or even '07s .
Old 06-05-2010, 07:22 PM   #17
Hershey
went back to dealer and they found it to be a leaking head gasket . Dye was used to locate it . Pointed out the oil was seeping from the upper passenger side of rear corner of block . Will likely have to take it in later in the week and get a rental . I suggest others look out for this .
Old 06-06-2010, 11:34 AM   #18
Maxh91
Maxh91's Avatar
Drives: Red 3 Dr HB 2008 Auto.
My 08 Hatchback at 29 000KM (2 month ago ) did a oil leak but only 1 time.
My yaris has been manufactured in april. Same month as Hershey said.
Maxh91 is offline   Reply With Quote
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Where is my oil leak coming from? The Gearbox? MarkBond General Yaris / Vitz Discussion 1 08-25-2007 10:31 PM
