Old 03-19-2010, 09:54 AM   #1
rossman
Drives: 2006 YARIS RS
Short Squeek From Rear Brakes
Hi,
When in gear and holding the brakes, when the brake pedal is released a short squeeking sound occurs.
The squeek dosent occur until the high point of the pedal (just before my foot comes off) it also only occus when I am in gear, not when in neutral.
From the sounds of it, it sounds to be coming from the rear.
The brakes were serviced not to long ago so I dont think it's the pads.
Anyone come across this problem?
Any suggestions, ideas that I can do before taking it to Toyota?
2006 RS Hatch
Automatic
ABS
Thanks,
rossman is offline   Reply With Quote
Old 03-19-2010, 08:13 PM   #2
bankrobber
Drives: 2007 Yaris Hatchback
not sure but mine has the same squeak. I would not waste time at dealer with that.
Old 03-19-2010, 08:42 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Probably backing plate needs to be lubed. Or a return spring is weak. Or just the drum is full of dust. Maybe try taking it apart cleaning the dust and adjusting the brakes first and see if that takes care of it.
http://www.yarisworld.com/forums/sho...light=drum+DIY
rear disc brakes 06silveryaris Performance Modifications 7 12-08-2009 08:22 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Rotated tires and adjusted rear brakes today PICS auxmike DIY / Maintenance / Service 11 11-14-2008 08:24 AM
REAR BRAKES KIT Yaris PTY-507 Performance Modifications 35 11-15-2006 12:23 PM
