Old 03-19-2010, 03:49 PM   #1
Moses
Drives: 08' Toyota Yaris Hatchback
How to change Transmission oil?
I found the drain plug but don't know how to re introduce new gear oil in the transmission i think its son bottle with a tube that screws in somewhere and refills it but i cant find that diy thread , help anyone? Gracias!
Moses
Urban Pacifica
Moses is offline   Reply With Quote
Old 03-19-2010, 03:52 PM   #2
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Moses
Urban Pacifica
Moses, What Type of tranny are you working with? Manual or Automatic ?
bobolinko is offline   Reply With Quote
Old 03-19-2010, 03:57 PM   #3
Moses
5sp hb
Old 03-19-2010, 04:02 PM   #4
Moses
i found the thread, Thanks buddy !
Old 03-19-2010, 06:51 PM   #5
bronsin
bronsin's Avatar
I use a gear oil pump, looks like a giant syringe. (or maybe a grease gun) $10 at Pep Boys.
Old 03-19-2010, 07:16 PM   #6
1stToyota
1stToyota's Avatar
Sta-Lube pump at Napa [SL4344] less than $10
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 03-20-2010, 12:45 AM   #7
Hershey
here's a way to get the torque right of the drain and filler plugs if don't have a torque wrench . Take a black SHARPIE pen with fine/ultra fine tip and draw a line on the tranny and the plugs before you remove them so they line up when retightened . Can be tightened a little bit more . That's how I did it for the gear oil changes . Also helps to mark the plugs with a F for FILLER PLUG and D for DRAIN PLUG or just one of the two . That way they line up properly . WAL-MART has a funnel with a clear plastic hose that can be inserted into the filler hole . Takes about 1 hour or so on 1st try . Gets easier second time around . Good Luck .
Old 03-21-2010, 11:21 AM   #8
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I bought some clear tubing and a funnel (Under $5). Put the tubing into the fill hole, put the funnel into the other end (snake tube up into the engine bay). Pour 2 quarts of fluid into the funnel. When you're done, pull out the tube, let any excess dribble out, plug everything up, drive :D
Old 03-21-2010, 12:01 PM   #9
Hershey
find window cleaner and paper towels to work well for cleaning up the oil that gets on the block . Changing gear oil is a fairly simple task .
Old 05-22-2010, 05:51 PM   #10
gliwa86
watev
Drives: toyota yaris 3dr
Moses
Urban Pacifica
hay man i have da same problem do u think uu could post some pics of specify where this illusive plug in and how u filled it back up, please
gliwa86 is offline   Reply With Quote
Old 05-23-2010, 12:07 PM   #11
ri_espinosa
ri_espinosa's Avatar
Drives: Toyota Tercel
Send a message via MSN to ri_espinosa Send a message via Yahoo to ri_espinosa
http://www.yarisworld.com/forums/showthread.php?t=8912
see this...
ri_espinosa is offline   Reply With Quote
Old 05-25-2010, 01:30 PM   #12
TheSilkySmooth
TheSilkySmooth's Avatar
I couldnt get my fill plug loose with a 1/2 Metre breaker bar! Luckily this is the first plug I loosed.
Old 02-10-2016, 01:39 PM   #13
strandrrs
Drives: 2009 Yaris 5-door Hatch
Run the car as fluid is being added?
Hi there -
If I'm adding transmission fluid where the dipstick is located (can I do that without draining, by the way?), should I run the car while adding it?
Thanks so much.
Marsha
strandrrs is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 02:55 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
