Old 03-20-2010, 04:18 PM   #1
djct_watt
Drives: 2010 NCP91 5spd
Sub/Hatch rattle
Even though I always complain about the Yaris' lack of rear cargo area, I went and got a nice 10" sub. The problem is that it's pumping out a decent amount of bass. . . so much that there is a very noticeable vibration/resonance/rattle coming from the rear in tune with low-mid to mid bass and not low low bass.
Is it just the plastic cover on the hatch or is it something in the plastic sides that is rattling? Any of you guys find out? I'd rather attack the source than to apply sound deadener to the entire rear end.
djct_watt is offline   Reply With Quote
Old 03-20-2010, 10:59 PM   #2
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
Play your system loud, and go back there and FIND the rattle.
Did you check your license plate? People tend to overlook that.
When I put my subwoofer in my Yaris hatch, I had no rattles.
Lucky me I guess.
Old 03-20-2010, 11:09 PM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Usually what happens is you quiet down one rattle, and you find another. You may want to try to face the sub a different direction, if you have it facing forward, face it back, or up, you have many different options to play with.
Old 03-21-2010, 01:52 AM   #4
djct_watt
Well it's definitely not the plate. . . the thai license plate is anchored down in such a way that it's not even moving at all. In CA, I was used to attacking the plate first. I dunno, it's none of the plastic trim on the surface of the interior, so I guess I just have to tear it apart.
I know I can "FIND" the rattle. But rather than tear the car apart, I was hoping to see if there were any common points I should check first.
Old 03-23-2010, 10:01 PM   #5
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
I am having the same issue and I notice that when I get out of the car and push on the hatch it goes away. Maybe we need to find a way to get the hatch to latch tighter? Also if I push on the plastics inside the hatch, nothig happens. I think it's gotta be the door itself. Let us know what you find out.
My Car Rules!
nickhjort is offline   Reply With Quote
Old 03-23-2010, 11:22 PM   #6
djct_watt
Yeah I fixed it. Not being a fan of dynamat and expensive/heavy deadeners, I cut up some old t-shirts and stuffed the back hatch. Problem solved.
Old 03-24-2010, 09:19 PM   #7
nice fix! lol
Old 03-25-2010, 08:51 AM   #8
swidd
Drives: Yaris HB
I put a queen size foam mattress in my doors, in addition to the expensive deadener.
Rattle noise under the speaker’s cover - sedan karat747 DIY / Maintenance / Service 1 10-22-2011 08:41 AM
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 12:29 AM
Dash rattle TSB needed ! tsportman DIY / Maintenance / Service 15 07-06-2009 06:20 PM
Exhaust rattle? Cutie Pie #2 DIY / Maintenance / Service 3 11-14-2008 06:46 PM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 08:39 PM
